Setting Static IP Address¶
In order to configure a static IP address, an entry needs to be made in systemd-network configuration directory
- Enter systemd-network directory
root@mitysom-am57x:~# cd /etc/systemd/network/
- By default there is a 15-eth.network which matches all eth* devices and configures them for dhcp
root@mitysom-am57x:/etc/systemd/network# cat 15-eth.network [Match] Name=eth* KernelCommandLine=!root=/dev/nfs [Link] RequiredForOnline=no [Network] DHCP=yes
- And there is 10-eth.network which only matches eth0, this has priority since the number is lower
root@mitysom-am57x:/etc/systemd/network# cat 10-eth.network [Match] Name=eth0 KernelCommandLine=!root=/dev/nfs [Network] DHCP=yes
- To configure eth0 for example to a static ip address, we create a 01-eth0.network file.
root@mitysom-am57x:/etc/systemd/network# vi 01-eth0.network [Match] Name=eth0 KernelCommandLine=!root=/dev/nfs [Network] Address=192.168.0.29/24 Gateway=192.168.0.1
This will take precedence since its the lowest numberroot@mitysom-am57x:/etc/systemd/network# ls 01-eth0.network 30-wlan.network 10-eth.network 50-usb-dhcpserver.network 15-eth.network 60-usb.network
