Source Code Repositories
The following are links to the repositories that Critical Link provides for the kernel, U-Boot, Yocto, and FPGA sample projects.
Pre-Built Images for the Development Kit
The following is a link to pre-built binaries for the development SD card image for the SOM variants. This will work with the FPGA or non-FPGA variants. It includes the preloader, uboot, and root filesystem.
Note: The SD-Card Image requires a 16GB+ sd card.
For flashing the Micro-SD card, we recommend using balenaEtcher. As it will handle unzipping and checking the md5sum for you.
Reference Toolchain Image
The following is a link to the Reference Linux Developer Toolchain based on TI's AM57xx PROCESSOR-SDK-LINUX)
