Example EEPROM¶
As noted in the Development Kit data-sheet:
A 256 Kbit EEPROM, U11, is available for user configuration information on the MitySOM-AM57(F) Development Board. This EEPROM is accessible over the I2C5 interface to the AM57xx processor.
Goal¶
These notes indicate how to access the Baseboard EEPROM from within Linux.
Prerequisites¶
- I2C5 as indicated in the data sheet is known internally to Linux as i2c-4.
 - The address of the EEPROM device is 50.
 - The device file for the EEPROM is /sys/bus/i2c/devices/4-0050/eeprom
Steps¶
- Display the current values in the eeprom.
root@mitysom-am57x:~# od -xc /sys/bus/i2c/devices/4-0050/eeprom 0000000 ffff ffff ffff ffff ffff ffff ffff ffff 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 * 0100000 root@mitysom-am57x:~# # The above indicates that all of the bytes in the eeprom have values of 0xff.
- Write values to the eeprom.
root@mitysom-am57x:~# echo Hello World > /sys/bus/i2c/devices/4-0050/eeprom
- Display the just written value in the eeprom
root@mitysom-am57x:~# od -xc /sys/bus/i2c/devices/4-0050/eeprom 0000000 6548 6c6c 206f 6f57 6c72 0a64 ffff ffff H e l l o W o r l d \n 377 377 377 377 0000020 ffff ffff ffff ffff ffff ffff ffff ffff 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 * 0100000 root@mitysom-am57x:~#
- Bulk read of entire contents.
root@mitysom-am57x:~# dd if=/sys/bus/i2c/devices/4-0050/eeprom of=eeprom_contents bs=4096 count=8 8+0 records in 8+0 records out # verify contents root@mitysom-am57x:~# od -cx eeprom_contents 0000000 H e l l o W o r l d \n 377 377 377 377 6548 6c6c 206f 6f57 6c72 0a64 ffff ffff 0000020 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 ffff ffff ffff ffff ffff ffff ffff ffff * 0100000 root@mitysom-am57x:~#
- Writing 0's to entire contents
root@mitysom-am57x:~# dd if=/dev/zero of=/sys/bus/i2c/devices/4-0050/eeprom bs=4096 count=8 8+0 records in 8+0 records out root@mitysom-am57x:~# od -cx /sys/bus/i2c/devices/4-0050/eeprom 0000000 \0 \0 \0 \0 \0 \0 \0 \0 \0 \0 \0 \0 \0 \0 \0 \0 0000 0000 0000 0000 0000 0000 0000 0000 * 0100000 root@mitysom-am57x:~#
- Writing 0xff to entire contents
# use tr to translate the 0's to 0xff root@mitysom-am57x:~# cat /dev/zero | tr "\0" "\xff" | dd of=/sys/bus/i2c/devices/4-0050/eeprom bs=4096 count=8 8+0 records in 8+0 records out root@mitysom-am57x:~# od -cx /sys/bus/i2c/devices/4-0050/eeprom 0000000 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 377 ffff ffff ffff ffff ffff ffff ffff ffff * 0100000 root@mitysom-am57x:~#
Conclusion¶
Given one or more of the commands above, you should be able to read and write the EEPROM. Similar operations could be performed in a program.
