Building DSP Example Projects¶
The following guide will walk you through installing the toolchains and building their example code. The dsp firmware will be loaded over remoteproc from linux.
http://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components_IPC.html#overview
Also check out the following link for different ways you can decide to interact with the DSP depending on your use cases.
http://software-dl.ti.com/processor-sdk-linux/esd/docs/06_03_00_106/linux/Foundational_Components_IPC.html#multiple-ways-of-arm-dsp-communication
Integrating DSP project with Yocto¶
TODO
