Offset (Byte) Register D15 D14 D13 D12 D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0
0x00 Base Version Register See Core Version Register Description
0x02 IRQ0_FLAGS_1 IRQ0_VECTOR_PENDING[15:0]
0x04 IRQ0_FLAGS_2 IRQ0_VECTOR_PENDING[31:16]
0x06 IRQ0_ENABLES_1 IRQ0_VECTOR_ENABLE[15:0]
0x08 IRQ0_ENABLES_2 IRQ0_VECTOR_ENABLE[31:16]
0x0A IRQ0_ENABLES_SET_1 IRQ0_VECTOR_ENABLE_SET[15:0]
0x0C IRQ0_ENABLES_SET_2 IRQ0_VECTOR_ENABLE_SET[31:16]
0x0E IRQ0_ENABLES_CLR_1 IRQ0_VECTOR_ENABLE_CLR[15:0]
0x10 IRQ0_ENABLES_CLR_2 IRQ0_VECTOR_ENABLE_CLR[31:16]
0x12 IRQ1_FLAGS_1 IRQ1_VECTOR_PENDING[15:0]
0x14 IRQ1_FLAGS_2 IRQ1_VECTOR_PENDING[31:16]
0x16 IRQ1_ENABLES_1 IRQ1_VECTOR_ENABLE[15:0]
0x18 IRQ1_ENABLES_2 IRQ1_VECTOR_ENABLE[31:16]
0x1A IRQ1_ENABLES_SET_1 IRQ1_VECTOR_ENABLE_SET[15:0]
0x1C IRQ1_ENABLES_SET_2 IRQ1_VECTOR_ENABLE_SET[31:16]
0x1E IRQ1_ENABLES_CLR_1 IRQ1_VECTOR_ENABLE_CLR[15:0]
0x20 IRQ1_ENABLES_CLR_2 IRQ1_VECTOR_ENABLE_CLR[31:16]
0x22 IRQ_CPU_MAP_SET IRQNUM RSV IRQ_VEC RSV CPUID
0x24 IRQ_CPU_MAP_1 0 IRQ0[4] IRQ0[3] IRQ0[2] IRQ0[1] IRQ0[0]
0x26 IRQ_CPU_MAP_2 0 IRQ0[9] IRQ0[8] IRQ0[7] IRQ0[6] IRQ0[5]
0x28 IRQ_CPU_MAP_3 0 IRQ0[14] IRQ0[13] IRQ0[12] IRQ0[11] IRQ0[10]
0x2A IRQ_CPU_MAP_4 0 IRQ0[19] IRQ0[18] IRQ0[17] IRQ0[16] IRQ0[15]
0x2C IRQ_CPU_MAP_5 0 IRQ0[24] IRQ0[23] IRQ0[22] IRQ0[21] IRQ0[20]
0x2E IRQ_CPU_MAP_6 0 IRQ0[29] IRQ0[28] IRQ0[27] IRQ0[26] IRQ0[25]
0x30 IRQ_CPU_MAP_7 0000000000 IRQ0[31] IRQ0[30]
0x32 IRQ_CPU_MAP_8 1 IRQ1[4] IRQ1[3] IRQ1[2] IRQ1[1] IRQ1[0]
0x34 IRQ_CPU_MAP_9 1 IRQ1[9] IRQ1[8] IRQ1[7] IRQ1[6] IRQ1[5]
0x36 IRQ_CPU_MAP_10 1 IRQ1[14] IRQ1[13] IRQ1[12] IRQ1[11] IRQ1[10]
0x38 IRQ_CPU_MAP_11 1 IRQ1[19] IRQ1[18] IRQ1[17] IRQ1[16] IRQ1[15]
0x3A IRQ_CPU_MAP_12 1 IRQ1[24] IRQ1[23] IRQ1[22] IRQ1[21] IRQ1[20]
0x3C IRQ_CPU_MAP_13 1 IRQ1[29] IRQ1[28] IRQ1[27] IRQ1[26] IRQ1[25]
0x3E IRQ_CPU_MAP_14 1000000000 IRQ1[31] IRQ1[30]
0x40 IQC_CPU_MAP_14_DUP 1000000000 IRQ1[31] IRQ1[30]
0x42 FPGA_VERSION See Core Version Register Description
