Example Projects
Below are the reference projects found in the following repository:
Type Repo Branch
Quartus Example Projects git://support.criticallink.com/home/git/mitysom-a5e-ref.git pro_25.3.1_stable
mitysom-a5e[-mini]-ref-base
This is the base reference design project. It contains the minimum configuration for the HPS to boot Linux with USB support and USB console. The FPGA design contains a sys_id module and input/output PIOs that can be attached to misc IO on the development board. This is a good starting point to extend a design from.
mitysom-a5e[-mini]-ref-dma
This is the base reference design project with mSGDMAs in the Fabric that can move data to / from the HPS's DDR memory.
mitysom-a5e[-mini]-ref-sfp-fabric
This is a reference design for the MitySOM or MitySOM-Mini Development kit to run 10G SFP loopback to a packet client in fabric.
mitysom-a5e-ref-fpga-emif
This is the base reference design project with the FPGA EMIF subsystem for reference. This is a useful starting point if you need to access the FPGA's RAM in your design.
mitysom-a5e-mini-ref-hvio
This is the base reference design project with the HVIO subsystem to allow for the use of pins accessible from the P8 and P9 connectors.
NOTE: Please contact Critical Link for the reference designs listed below.
mitysom-a5e-pcie-gen3x4-rp
This is a reference design for the MitySOM-A5 Development kit to run the m.2 M-Key (NVME) in PCIe Gen 3x4 lane root port data mode in order to support reading / writing NVME cards or other PCIe devices that can be inserted into the m.2 M-Key interface.
mitysom-a5e-pcie-gen4x4-rp
This is a reference design for the MitySOM-A5 Development kit to run the m.2 M-Key (NVME) in PCIe Gen 4x4 lane root port data mode in order to support reading / writing NVME cards or other PCIe devices that can be inserted into the m.2 M-Key interface. This project requires a speed grade 4 or better MitySOM-A5 device.
mitysom-a5e-pcie-gen3x1-rp
This is a reference design for the MitySOM-A5 Development kit to run the m.2 E-Key (wifi) in PCIe Gen 3x1 lane root port data mode in order to support reading / writing wifi cards or other PCIe devices that can be inserted into the m.2 E-Key interface.
mitysom-a5e-pcie-gen3x4-ep
This is a reference design for the MitySOM-A5 Development kit to support interfacing with a HOST PC running linux via the PCIe edge connector interface using a Samtec PCIe x4 style riser cable.
