A5E-Base-Example¶
Overview¶
The A5E base example is an HPS-centric reference design. The base configuration is intended as a clean starting point for HPS boot, memory bring-up, and peripheral validation.
The primary purpose of this design is to:
- Bring up the Agilex 5 HPS
- Connect the HPS to onboard LPDDR4 through the HPS EMIF controller
- Expose the board's HPS-connected peripheral interfaces for software development and platform bring-up
- Provide a small amount of FPGA-side support logic that the HPS can access through the lightweight HPS-to-FPGA bridge
In other words, this project is a clean starting point for HPS boot, Linux bring-up, peripheral validation, and incremental expansion of the design.
│ LPDDR4 Memory │
│ via HPS EMIF Controller │
│ HPS EMIF
│ Agilex 5 HPS │
│ - Boot / application processing │
│ - Peripheral controllers and HPS I/O │
│ - HPS GP signals │
│ HPS pins │ Lightweight
│ to board I/O │ HPS-to-FPGA
│ │ bridge
│ Board-Level HPS Interfaces │ │ Minimal FPGA Support Logic │
│ - SD/MMC │ │ - sysid │
│ - USB / Ethernet / serial │ │ - 32-bit PIO input/output │
│ - I2C / I3C / GPIO │ │ - USB-C interrupt PIO │
│ │ │ - reset / board glue │
What This Project Offers¶
This project is useful as a base platform because it already provides:
- A known-good HPS + LPDDR4 hardware starting point
- HPS peripheral pin muxing for the board-level interfaces needed for software bring-up
- A lightweight HPS-to-FPGA control path for simple registers and board support functions
- A minimal fabric footprint that is easy to understand and extend
HPS-Connected Peripheral Interfaces¶
The base design primarily exposes HPS peripheral pins rather than custom FPGA logic. In the current base configuration this includes:
- SD/MMC interface signals, along with card-detect and media-select style GPIO support
- USB1 ULPI signals and USB 3.1 sideband/PHY support signals
- USB 2.0 ULPI signals (MitySOM Only)
- EMAC1 Ethernet interface signals (MitySOM-Mini Only)
- MDIO management signals for Ethernet PHY bring-up (MitySOM-Mini Only)
- UART1 for serial console / software interaction
- I2C1 for board-level peripheral access
- I3C0 for additional peripheral connectivity
- Miscellaneous GPIO-based board control signals such as reset, presence-detect, and enable lines
FPGA-Side Support Logic¶
The design still includes a few useful support blocks:
- Sysid so software can identify the generated hardware build
- PIO output 32-bit register space on the lightweight HPS-to-FPGA bridge
- PIO input 32-bit register space on the lightweight HPS-to-FPGA bridge
- USB-C interrupt PIO so the HPS can observe the external USB-C interrupt line through an IRQ-capable register
These blocks are intended for simple platform control/status functions rather than high-bandwidth data movement.
HPS GP / Board Bring-Up Hooks¶
The design also leaves a few simple HPS-to-fabric hooks in place that are useful during bring-up:
- HPS GP output is used to release the fabric from reset
- HPS GP outputs are used to drive debug LEDs
- The lightweight HPS-to-FPGA bridge can be used to add more simple board-control features later without restructuring the design
Why Use This Project¶
The A5E base example is a good starting point when you want:
- HPS boot and memory bring-up without extra FPGA datapath complexity
- A software-first platform for Linux, drivers, or board validation
- A baseline design that can later be extended with FPGA peripherals or custom accelerators
Building the FPGA Design Base Example¶
Compile the FPGA design¶
Refer to Building_fpga_2531pro for building the FPGA design. Navigate into the mitysom-a5e[-mini]-ref-base example project before compiling the design.
- Ensure to flash the resulting a5e.hps.jic onto the hardware
- Ensure to replace the a5e.core.rbf on the SD card
