A5E-FPGA-EMIF-Example¶
Overview¶
The A5E FPGA EMIF example builds on the base A5E design and adds an FPGA-side LPDDR4 memory subsystem.
The HPS platform and board-level bring-up infrastructure from the base design are still present, but the primary feature of this example is the fpga_emif_subsys. This subsystem instantiates the Intel LPDDR4 EMIF IP and the support blocks needed to clock it, reset it, and present a fabric-facing memory access interface.
This example is best viewed as a subsystem integration reference design. It shows how the FPGA LPDDR4 interface is brought into the project and wired up, while leaving room for future user logic or traffic-generation logic to be added around it.
FPGA EMIF Subsystem¶
The FPGA EMIF subsystem contains four main blocks:
- fpga_emif_0 - Intel LPDDR4 EMIF IP
- s0_axi4_clock_bridge_0 - provides the internal subsystem clock
- s0_axi4_reset_bridge_0 - provides the internal subsystem reset
- s0_axi4_mm_bridge_0 - bridges the fabric-side Avalon-MM interface to the EMIF AXI4 interface
User traffic should be connected on the fabric-facing s0 side of s0_axi4_mm_bridge_0.
At the top level of the design:
- The subsystem clock is driven from hps_subsys.intel_agilex_5_soc_0_h2f_user0_clk
- The subsystem reset is driven from fabric_reset_bridge_0.out_reset
- The LPDDR4 pins and EMIF reference clock are exported to the FPGA-side memory interface pins
hps_subsys.intel_agilex_5_soc_0_h2f_user0_clk (100 MHz example) FPGA_CLKIN_P
▼ │ ref_clk
│ s0_axi4_clock_bridge_0 │ ┌──────────────────────────┐ LPDDR4 pins ┌───────────────┐
└──────────────────┬───────┘ │ fpga_emif_0 │◄──────────────►│ FPGA LPDDR4 │
│ │ (LPDDR4 EMIF IP) │ └───────────────┘
├─────── clock ────────► └──────────────────────────┘
│ │ AXI4 │
Avalon-MM ┌──────────────────────────┐ │ │
Connection to user logic ◄───────────────►│ s0_axi4_mm_bridge_0 │◄────────────┘ │
│ (Avalon-MM to AXI4) │ │
│ reset │
fabric_reset_bridge_0.out_reset ───► │ s0_axi4_reset_bridge_0 │
What This Project Offers¶
This project provides:
- A reference integration of FPGA-side LPDDR4 on the A5E platform
- A ready-made EMIF subsystem with clock, reset, and MM-to-AXI4 bridge structure already assembled
- A clear starting point for adding FPGA masters, test logic, or application logic that need external LPDDR4
- The same HPS bring-up platform as the base design, with the FPGA EMIF subsystem added alongside it
Memory Path¶
The important data path in this example is:
- Fabric-side Avalon-MM traffic enters s0_axi4_mm_bridge_0
- The bridge converts that traffic to the AXI4 interface expected by fpga_emif_0
- The EMIF IP drives the external FPGA LPDDR4 memory interface
The subsystem's fabric-side integration point is the s0 side of s0_axi4_mm_bridge_0. No master is attached to that interface in the current example.
Clocking and Reset¶
The FPGA EMIF subsystem is integrated into the rest of the design as follows:
- s0_axi4_clock_bridge_0 fans out the subsystem clock
- That clock is used by the MM bridge and by the EMIF IP control/data interfaces
- s0_axi4_reset_bridge_0 fans out the subsystem reset
- That reset is applied to the MM bridge and the EMIF IP initialization/control interfaces
- In this design, the subsystem clock bridge is fed from the user clock, which is 100 MHz in this example
- This is useful for integration and bring-up, but it will not allow full bandwidth to the FPGA LPDDR4
- If higher bandwidth is desired, connect s0_axi4_clock_bridge_0 to a faster clock source
External FPGA LPDDR4 Interface¶
The EMIF IP exports the expected FPGA-side LPDDR4 signals, including:
- LPDDR4 reference clock input
- CK / CKE / CS / CA control signals
- DQ / DQS / DMI data signals
- Memory reset
- OCT / RZQ support signal
These signals are pinned out in the generated project and connected to the FPGA-side LPDDR4 memory interface on the board.
Scope of This Example¶
This example focuses on integrating the FPGA EMIF subsystem itself.
It does not add a dedicated traffic generator, benchmark engine, or end-user memory test application around the subsystem. In the current top-level design, the subsystem is integrated, clocked, reset, and pinned out, but no example traffic source is attached to exercise the memory path.
That makes this design a good base for:
- adding custom FPGA masters
- adding a simple memory test block
- extending the design into a higher-level memory-access example later
Building the FPGA EMIF Example¶
Compile the FPGA design¶
Refer to Building_fpga_2531pro for building the FPGA design. Navigate into the mitysom-a5e-ref-fpga-emif example project before compiling the design.
- Ensure to flash the resulting a5e.hps.jic onto the hardware
- Ensure to replace the a5e.core.rbf on the SD card
