MKFail to program device
Added by Maxim Kanevsky about 1 year ago
Hello
I've just got MitySOM_A5 Dev. Kit and started to work on it.
I'm trying to create my own project based on CriticalLink BASE Example Project (clone from GIT, PRO 24.2 Stable)
The idea is not to use HPS for this project, but FPGA fabric only.
When I compiled the project, trying to program it, it just fails and there is no error message:
Probably something wrong in QSF file
Attaching the archived project in Q24.2.0
Thanks!!!
Replies (8)
MF RE: Fail to program device - Added by Mike Fiorenza about 1 year ago
Maxim,
Please use the instructions found here for programming the QSPI NOR Flash (from the command line): https://support.criticallink.com/redmine/projects/mitysom_a5/wiki/Building_fpga_242pro
I have not found a way to get the Programming GUI to work with the Agilex 5 part yet since this device uses an SDM and separates the devices into two separate targets (ARM vs FPGA). This is also how Altera documents programming the flash on their development kit.
MK RE: Fail to program device - Added by Maxim Kanevsky about 1 year ago
Hello Mike,
I'm going to follow the instructions.
But, since we are using FPGA ONLY (no HPS), should this instructions to be applied, or we can generate .jic only??
Also, I'm not sure about your comment regarding Programming GUI. Do you mean, that the programming can be done only by the command: quartus_pgm -m jtag -o "piv;output_files/a5e.hps.jic@2"
Max
You'll have to change our reference design from HPS First to FPGA first. This can be done by removing the "HPS FIRST" assignment in the QSF as well as do not provide the "--hps=on" when using the quartus_pfg command to generate the jic.
Either way (HPS or FPGA first) a JIC can be created and programmed via the command line you listed above.
Correct, I am unaware of a solution to program the JIC/SOF via the Programming GUI only via command line.
You can also directly program the FPGA via the SOF instead of the JIC. It would still use the same command: quartus_pgm -m jtag -o "p;output_files/a5e.sof@2"
But the SOF needs to be programmed every power cycle and isn't persistent like flashing the JIC into flash.
Hello Mike,
Thanks again for your help!!!
I've followed the instructions that you send me yesterday. The command "make jic" compiled the design.
I see directory software and under the path that specified in instructions, also in the folder output_files, no specified files:
But, the compilation passed successfully. What's wrong???
I followed the instructions as described. Run with Q24.2.0
Max
Did you make changes to the design to switch to FPGA first as described in my previous post? Or are you just trying to compile the reference design as is?
If you made changes to the design can you please list those changes and upload the files changed?
Hello Mike,
No I didn't made any changes. I removed everything. I clone again, navigate to directory and run command "make jic". It run again and again no files as expected
Mike, please see attached log of the compilation
log.txt (169 KB) log.txt
As shown by the log file it appears that you do not have the ARM toolchain installed. It is failing to compile the bootloader code. Please follow this wiki to install the GCC-ARM-11.2 toolchain.
https://support.criticallink.com/redmine/projects/mitysom_a5/wiki/Prerequisites_242pro
    (1-8/8)
