Example Projects
Below are the reference projects found in the following repository:
Type Repo Branch
Quartus Example Projects git://support.criticallink.com/home/git/mitysbc-a5-ref.git pro_25.3.1_stable
mitysbc-a5e-ref-base
This is the base reference design project. It contains the minimum configuration for the HPS to boot Linux with USB support and USB console. The FPGA design contains a sys_id module and input/output PIOs that can be attached to misc IO on the development board. This is a good starting point to extend a design from.
mitysbc-a5e-ref-dma
This is the base reference design project with mSGDMAs in the Fabric that can move data to / from the HPS's DDR memory. Further instructions for running this example design can be found here A5E-DMA-Example
mitysbc-a5e-ref-fpga-emif
This is the base reference design project with the FPGA EMIF subsystem for reference. This is a useful starting point if you need to access the FPGA's RAM in your design.
