DPStill requires ifdown eth0 / ifup eth0 (DHCP)
Added by Daniel Paley almost 13 years ago
I'm still having trouble with the dns services. I've narrowed it down to two items:
1). at boot I still need to log into the machine and run ifdown eth0; ifup eth0
2). or sometime a restart of the avahi-daemon.services (systemctl start avahi-daemon.service) will also work
what am I doing wrong? seems that I've configured things correctly - and I've check around to see 'what else' could be causing the trouble. The mityDSP board just
sometime come up with out any issue (getting a dhcp IP correctly and registering on the DNS without issue) and at other times it cannot get either a DNS entry or even an IP address.
I've played with host to set this correctly. I've played with /lib/systemd/system/avahi-daemon.service and networking.service to no real solution.
Is there a requirement to have something additional to the networking.service file (such as a Before)?
Replies (4)
BD RE: Still requires ifdown eth0 / ifup eth0 (DHCP) - Added by Bob Duke almost 13 years ago
Hello Dan,
Are you using a custom filesystem or an example filesystem from our MDK? Are you running with the MityDSP-L138 module in our development board or from your own baseboard?
Could you post the contents of your networking.service file, as well as the contents of /etc/network/networking?
-Bob
DP RE: Still requires ifdown eth0 / ifup eth0 (DHCP) - Added by Daniel Paley almost 13 years ago
I believe that I'm using the 'released' version of hte file system (MDK).
root@mityT1-dev:/lib/systemd/system# more networking.service
[Unit]
Description=Networking
Before=getty@tty1.service display-manager.service app.service
After=dev-tty1.device
[Service]
ExecStart=-/etc/init.d/networking start
Type=oneshot
[Install]
WantedBy=multi-user.target
There is not directory /et/networking - enclosed is the interfaces from from /etc/network/interfaces.
- /etc/network/interfaces -- configuration file for ifup(8), ifdown(8)
- The loopback interface
auto lo
iface lo inet loopback
- Wireless interfaces
iface wlan0 inet dhcp
wireless_mode managed
wireless_essid any
wpa-driver wext
wpa-conf /etc/wpa_supplicant.conf
iface atml0 inet dhcp
- Wired or wireless interfaces
auto eth0
iface eth0 inet dhcp
hostname mityT1-dev # set to my host name
iface eth1 inet dhcp
- Ethernet/RNDIS gadget (g_ether)
- ... or on host side, usbnet and random hwaddr
iface usb0 inet static
address 192.168.7.2
netmask 255.255.255.0
network 192.168.7.0
gateway 192.168.7.1
- Bluetooth networking
iface bnep0 inet dhcp
Sorry - files formated above, enclosed below
--Daniel
| sample1.txt (1.07 KB) sample1.txt |
adding a bit more information:
seems that I'm not getting dbus.service or avahi-daemon.service starting automatically. systemctl reports:
avahi-daemon.service loaded inactive dead Avahi mDNS/DNS-SD Stack
dbus.service loaded inactive dead D-Bus System Message Bus
non-working log included.
