Building the Filesystem¶
1. Prerequisites 2. Building the FPGA and Bootloader 3. Building the Filesystem 4. Deploying the Firmware
Introduction¶
The filesystem is built through Yocto. The Yocto version is scarthgap and should be compiled using Ubuntu 22.04.
The meta-layers for the Yocto build are as follows.| Repository | URL | Branch |
| poky | https://git.yoctoproject.org/poky | scarthgap |
| meta-openembedded | https://github.com/openembedded/meta-openembedded | scarthgap |
| meta-mitysom | https://support.criticallink.com/git/meta-mitysom.git | scarthgap |
It is recommended to use Docker for the Yocto build. Instructions for installing Docker can be found here: Docker Installation Guide
The recommended Docker container can be fetched using the command below.
Setting up Yocto¶
Clone the Yocto layers¶
git clone -b scarthgap https://git.yoctoproject.org/poky cd poky git clone -b scarthgap https://github.com/openembedded/meta-openembedded git clone -b scarthgap https://support.criticallink.com/git/meta-mitysom.git
Launch the Docker container¶
Source the Yocto environment¶
. ./oe-init-build-env
Copy the example configuration files¶
cp ../meta-mitysom/conf/bblayers.conf.sample conf/bblayers.conf cp ../meta-mitysom/conf/local.conf.sample conf/local.conf
Performing the Yocto build¶
Build the filesystem¶
MACHINE=mity-a5e bitbake mitysom-image-base
Outputs¶
| Description | Location |
| Filesystem Tarball | <Yocto Directory>/build/tmp/deploy/images/mity-a5e/mitysom-image-base-mity-a5e.tar.gz |
Build the SDK¶
Build the SDK¶
MACHINE=mity-a5e bitbake mitysom-image-base -c populate_sdk
Outputs¶
| SDK Script | <Yocto Directory>/build/tmp/deploy/sdk/*mitysom-image-base*toolchain*.sh |
