Building the FPGA project and Bootloader with Quartus Pro 25.3.1
1. Prerequisites 2. Building the FPGA and Bootloader 3. Building the Filesystem 4. Deploying the Firmware
Introduction
The reference project for the MitySOM-A5E requires the Quartus Pro 25.3.1 tools installed and in your path.
Platform Description Repository Branch
Mity-A5E Quartus Example Projects git://support.criticallink.com/home/git/mitysom-a5e-ref.git pro_25.3.1_stable
Quick steps to build
Clone the repository
git clone -b pro_25.3.1_stable git://support.criticallink.com/home/git/mitysom-a5e-ref.git
Navigate into the folder for the reference Quartus project desired to build (E.g. MODEL_NUMBER/mitysom-a5e-mini-ref-base)
cd mitysom-a5e-ref/A5ED-B14-1X8-MRC-B0/mitysom-a5e-mini-ref-base
Build the FPGA project and Bootloader
make jic
Refer to the 4. Deploying the Firmware section for updating the SD card and flashing the QSPI NOR with the JIC file.
Bootloader
Bootloader Environment
The bootloader environment script can be found in scripts/boot.cmd. This is bootloader script that is ran as part of the boot process. The script can be compiled by running the following:
make uboot_script
The compiled output script will be in scripts/boot.scr, this belongs in the FAT partition
