Building SD Card
  • Linux PC (Ubuntu 22.04)
  • libguestfs-tools
  • vmlinux set a readable (note: this needs to be done every time the kernel is upgraded)
sudo chmod a+r /boot/vmlinuz*
  • Filesystem Tarball from Yocto (mitysom-image-base-mitysbc-agilex5.tar.gz)
  • Bootloader from FPGA build (u-boot.itb)
  • Bootloader script from FPGA build (boot.scr)
  • Kernel Image from Yocto deploy directory or built manually (Image)
  • Kernel device tree from Yocto deploy directory or built manuall (socfpga_agilex5_mitysbc.dtb)
Make SD script
The make_sd.sh script can be found in the FPGA project base_project/software/make_sd.sh
Run this script to generate an SD card image
./make_sd.sh \
    -a \
    -o sd_card.img \
    -d Agilex5 \
    -f path/to/u-boot.itb \
    -f path/to/boot.scr \
    -f path/to/Image \
    -f path/to/socfpga_agilex5_mitysbc.dtb \
    path/to/mitysom-image-base-mitysbc-agilex5.tar.gz
The following will generate an sd_card.img that can be flashed onto an SD card
Manually updating any binaries on an existing SD card
The SD card has two partitions, a FAT partition and an EXT partition. The EXT partition contains the Linux filesystem and the FAT partition contains the rest of the binaries.
To update any of the binaries, first mount the FAT partition:
sudo mount /dev/sdX1 /mnt
The /mnt directory now contains the FAT partition and any of the binaries (u-boot.itb, boot.scr, Image, socfpga_agilex5_mitysbc.dtb) can now be replaced
When complete, the partition can be unmounted with the following:
sudo umount /dev/sdX1
