Building the FPGA project and Bootloader with Quartus Pro 24.1¶
Introduction¶
The reference project for the MitySBC-Agilex5 requires the Quartus Pro 24.1 tools installed and in your path.
| Quartus Example Projects | git://support.criticallink.com/home/git/mitysbc-a5-ref.git | pro_24.1_stable |
Quick steps to build¶
Clone the repository¶
git clone -b pro_24.1_stable git://support.criticallink.com/home/git/mitysbc-a5-ref.git
Navigate into the root of the Quartus project¶
cd mitysbc-a5-ref/base_project
Generate the project¶
The project is set up to be customizable from TCL. To generate the default configuration run the following:
make generate_from_tcl
make jic
This will result in output_files/base_project_hps.jic. The JIC file contains the FPGA design and the preloader which is programming into the QSPI NOR.
Program the QSPI NOR with the FPGA design / Preloader¶
quartus_pgm -m jtag -o "ip;output_files/base_project_hps.jic@2"
Bootloader¶
Bootloader Environment¶
make uboot_script
The compiled output script will be in software/boot.scr
