NOSPI bringup
Added by Nathan Olson 5 months ago
Are there any reference examples of software using SPI? I'm attempting to configure the QUP to use SPI on my carrier board.
Here's my device tree modification:
&spi12 {
status = "okay";
/*... SPI device config...*/
And here's my trust zone modification:
/* PeriphID, ProtocolID, Mode, NsOwner, bAllowFifo, bLoad, bModExcl */
{ QUPV3_1_SE4, QUPV3_PROTOCOL_SPI, QUPV3_MODE_FIFO, AC_HLOS, TRUE, TRUE, FALSE },
The boot crashes with the following error:
[ 5.028870][ T123] cpufreq-dt cpufreq-dt: failed register driver: -17 [ 5.095297][ T417] sc7280-pinctrl f100000.pinctrl: pin-48 (a90000.spi) status -22 [ 5.105331][ T417] sc7280-pinctrl f100000.pinctrl: could not request pin 48 (GPIO_48) from group gpio48 on device f100000.pinctrl [ 5.105595][ T401] Internal error: synchronous external abort: 0000000096000010 [#1] PREEMPT SMP [ 5.106015][ T414] gpi a00000.dma-controller: Adding to iommu group 10 [ 5.117481][ T417] geni_spi a90000.spi: Error applying setting, reverse things back [ 5.126576][ T401] Modules linked in: typec(+) qcom_stats(+) qcom_q6v5_pas(+) spi_geni_qcom(+) gpi(+) i2c_qcom_geni(+) llcc_qcom icc_bwmon(+) qcom_rproc_minidump qcom_pil_info snd_soc_lpass_wsa_macro snd_soc_lpass_rx_macro snd_soc_lpass_ô[ 5.201973][ T401] CPU: 3 PID: 401 Comm: (udev-worker) Tainted: G O 6.6.90-qli-1.5-ver.1.1-04509-gc4b8666c9a55-dirty #1 [ 5.215658][ T401] Hardware name: Critical Link MitySOM-QC6490 (DT) [ 5.222737][ T401] pstate: 60400005 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 5.231688][ T401] pc : geni_i2c_probe+0x318/0x7d4 [i2c_qcom_geni] [ 5.238691][ T401] lr : geni_i2c_probe+0x318/0x7d4 [i2c_qcom_geni] [ 5.245674][ T401] sp : ffffffc086233840 [ 5.250315][ T401] x29: ffffffc086233840 x28: ffffffc086233bb0 x27: ffffffd9429e6d60 [ 5.259372][ T401] x26: ffffffc086088068 x25: ffffff8083b5f810 x24: 0000000000000000 [ 5.268436][ T401] x23: ffffffd9429e6d60 x22: ffffff8083b5f800 x21: ffffff8083b5f810 [ 5.277498][ T401] x20: ffffff8082469080 x19: 0000000000000000 x18: ffffffd9442559b0 [ 5.286565][ T401] x17: ffffffd944255998 x16: ffffffd9427b8728 x15: 00000000000002d2 [ 5.295632][ T401] x14: 0000000000000000 x13: ffffff8081055400 x12: 0000000000000002 [ 5.304699][ T401] x11: 0000000130503bbe x10: 0000000000000b10 x9 : ffffff8080ce6450 [ 5.313768][ T401] x8 : ffffffc086233408 x7 : 0000000000000000 x6 : 0000000000000000 [ 5.322838][ T401] x5 : ffffffd942a16320 x4 : ffffffd942a16364 x3 : ffffffd9429e6d60 [ 5.331918][ T401] x2 : ffffffd91e131b3c x1 : ffffffc086088068 x0 : 0000000000000020 [ 5.341016][ T401] Call trace: [ 5.344768][ T401] geni_i2c_probe+0x318/0x7d4 [i2c_qcom_geni] [ 5.351372][ T401] platform_probe+0x68/0xc8 [ 5.356381][ T401] really_probe+0x148/0x2b0 [ 5.361380][ T401] __driver_probe_device+0x78/0x12c [ 5.367088][ T401] driver_probe_device+0x3c/0x15c [ 5.372605][ T401] __driver_attach+0x90/0x19c [ 5.377754][ T401] bus_for_each_dev+0x7c/0xe0 [ 5.382891][ T401] driver_attach+0x24/0x30 [ 5.387746][ T401] bus_add_driver+0xe4/0x208 [ 5.392767][ T401] driver_register+0x5c/0x124 [ 5.397864][ T401] __platform_driver_register+0x28/0x34 [ 5.403842][ T401] geni_i2c_driver_init+0x20/0x1000 [i2c_qcom_geni] [ 5.410897][ T401] do_one_initcall+0x58/0x2e4 [ 5.415971][ T401] do_init_module+0x58/0x1e4 [ 5.420942][ T401] load_module+0x1fa0/0x207c [ 5.425897][ T401] init_module_from_file+0x88/0xcc [ 5.431372][ T401] __arm64_sys_finit_module+0x148/0x328 [ 5.437281][ T401] invoke_syscall+0x48/0x114 [ 5.442203][ T401] el0_svc_common.constprop.0+0xc0/0xe0 [ 5.448091][ T401] do_el0_svc+0x1c/0x28 [ 5.452544][ T401] el0_svc+0x38/0xf8 [ 5.456716][ T401] el0t_64_sync_handler+0x120/0x12c [ 5.462208][ T401] el0t_64_sync+0x1a0/0x1a4 [ 5.466975][ T401] Code: 912cf042 9101a35a aa1a03e1 940003d2 (b9400353) [ 5.474250][ T401] ---[ end trace 0000000000000000 ]--- [ 5.480001][ T401] Kernel panic - not syncing: synchronous external abort: Fatal exception [ 5.489179][ T401] SMP: stopping secondary CPUs [ 5.494252][ T401] Triggering bite [ 5.498160][ T401] gh-watchdog hypervisor:qcom,gh-watchdog: Causing a QCOM Apps Watchdog bite! [ 5.507750][ T401] gh-watchdog hypervisor:qcom,gh-watchdog: vWdog-CTL: 1, vWdog-time since last pet: 1128, vWdog-expired status: 1
Any ideas?
NO RE: SPI bringup - Added by Nathan Olson 5 months ago
Edit: The boot crash in unrelated and I've resolved that. However, SPI configuration still fails:
[ 4.936978][ T376] sc7280-pinctrl f100000.pinctrl: request() failed for pin 48 [ 4.945645][ T376] sc7280-pinctrl f100000.pinctrl: pin-48 (a90000.spi) status -22 [ 4.954125][ T376] sc7280-pinctrl f100000.pinctrl: could not request pin 48 (GPIO_48) from group gpio48 on device f100000.pinctrl [ 4.967793][ T376] geni_spi a90000.spi: Error applying setting, reverse things back
My guess is that this is due to these lines in qcm6490.dtsi:
&tlmm {
gpio-reserved-ranges = <32 2>, <48 4>;
There's no comment describing what this is for. Is there any hope of getting these pins enabled as SPI on my carrier board?
The original commit message for those lines is "Add gpio-reserved-ranges for QCM6490 boards."
In mainline linux, I found the following in qcs6490-rb3gen2.dts:
&tlmm {
gpio-reserved-ranges = <32 2>, /* ADSP */
<48 4>; /* NFC */
I'm not using NFC, can I remove <48 4> from the gpio-reserved-ranges? Is there anything on the MitySOM using these pins?
MW RE: SPI bringup - Added by Michael Williamson 5 months ago
Hi Nathan,
I think you can remove the NFC pins and give it a shot.
