NWflash script needs to boot enable the device
Added by Nathan Wright over 1 year ago
Fyi we recently discovered the flash script located here...
...has a minor hole you might want to update.
We did not notice it at first because our dev board SOM had these steps completely manually in the development of the process.
But on brand new SOMs, the script does not succeed at making the emmc bootable.
We had to add these steps...
1. add mmc-utils to the image recipe
2. add this step to the script after the md5 hash check
# Boot enable the device
echo "Enable the emmc as a boot device"
mmc bootpart enable 1 1 ${mmc_dev}
mmc bootbus set single_backward x1 x8 ${mmc_dev}
That is all. Thanks!
JC RE: flash script needs to boot enable the device - Added by Jonathan Cormier over 1 year ago
Hi Nathan, Thanks for letting us know. I've pushed the fix to the kirstone and scarthgap branches.
