NWsuggestion: add parted and mtools to docker-pocky
Added by Nathan Wright about 2 years ago
You need them if you want to use the wic tool to inspect wic files that have fat partitions.
I attach to a running container as root and install them myself right now. It wouldn't hurt to have them in the image to begin with.
JB RE: suggestion: add parted and mtools to docker-pocky - Added by Joshua Bourgeot about 2 years ago
Hi Nathan,
The Docker-poky script uses the Crops poky docker image (https://hub.docker.com/r/crops/poky), so we don't have control over what's installed on the image.
However, Yocto does build those tools as part of the build process, so you can pass these tools to wic. You can see how this is done in this script: sources/meta-mitysom/recipes-bsp/sd-images/rename-gp-wic-images/rename-gp-wic-images.sh.
Let me know if this helps,
Joshua Bourgeot
NW RE: suggestion: add parted and mtools to docker-pocky - Added by Nathan Wright about 2 years ago
Thanks! Specifying -n to identify where the tools are does work.
