TRHSMC Control
Added by Travis Rawson over 5 years ago
I am trying to control the HSMC on my dev board(5csx). We have a in house created daughter board that we would like to control, but I am having a hard time controlling the HSMC. Is there some module for the Platform Designer or IP that I can download and use? The end goal is to read from an ADC on the board, but at this point I am simply trying to turn a pin on/off so I can use the test points we have.
I am using the "mitysom-5csx-ref" project as a base at the moment, and inside I have tried the following to no luck:
HSMC1_RX13 <= '1';
We have pins 13-16(both p and n) directly attached to test points.
Any help would be great!
DV RE: HSMC Control - Added by Daniel Vincelette over 5 years ago
Hi Travis,
We don't have a module or IP for the HSMC connectors. Though in the mitysom-5csx-ref project, all of HSMC pins do go to soft GPIO controllers that can be toggled from the processor.
I have a few things to double check/try:
  • In the pin planner, verify that HSMC1_RX13 is going to PIN_T11
  • Is the daughter card connected to the HSMC connector on the dev kit that says Full HSMC connector?
  • Does the pin number on the daughterboard HSMC schematic match the number on our dev kit? I only ask because I've seen some manufactures have slightly different number schemes.
Dan
TR RE: HSMC Control - Added by Travis Rawson over 5 years ago
Wow, I can't believe I overlooked that. Yes, I had it on the wrong HSMC connector. All is working perfectly now.
Thanks for the help!
    (1-2/2)
