GFSaving Continuous Frames Mity CAM
Added by Gashaw Fente over 9 years ago
I'm using Mity CAM-B2521F to capture continuous frames with MityView. While trying to save the frames, I can only see the last captured frame. Where are the other frames located to save them individually? Or the Save as function saves all the frames in one file?
MW RE: Saving Continuous Frames Mity CAM - Added by Michael Williamson over 9 years ago
In the mityviewer, if you select the View->Playback/Record option, there is a recording dialog that will save multiple frames. Can you check if this will resolve your issue?
