Auto run of application file (loaded in NAND Flash)
Added by Vivek Ponnani over 7 years ago
I have a custom board with
-- MityDspl-138F module (with FPGA)
-- No Ethernet port
-- UART,USB,SD CARD interface
We are using MMC card for booting linux and to copy application software files to board.
we have done following steps till date.
-- I have built VM with MityDSP Critical_Link_Unified_VM_14-04_04-2017.ova file from critical link.
-- I have successfully run the example programs.
-- I have build new kernel with Analog Expansion support. We followed https://support.criticallink.com/redmine/projects/90-000173/wiki for the build of new kernel.
-- I have prepared SD card and copy new Linux kernel and its file system. And also inserted the modules under /lib/modules/3.2.0+/extra as per the https://support.criticallink.com/redmine/projects/90-000173/wiki
Now, I want Linux kernel and FPGA image in SPI flash, Kernel Filesystem in NAND partition and application software image in NAND (userfs) partition.
Please answer my below queries.
1) Steps to program FPGA in SPI flash.
From the page https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Programming_the_FPGA
U-Boot > loadb 0xC0700000
  1. Ready for binary (kermit) download to 0xC0700000 at 115200 bps...
  2. Total Size = 0x00071544 = 464196 Bytes
  3. Start Addr = 0xC0700000
uBoot> sf probe 0
uBoot> sf erase 0x580000 0x80000
uBoot> sf write 0xC0700000 0x580000 ${filesize}
uBoot> setenv progfpga "sf probe 0; sf read 0xc0700000 0x580000 0x80000; loadfpga 0xc0700000"
uBoot> setenv bootcmd "run progfpga"
uBoot> saveenv
On restart every time FPGA will be programmed from the file stored in SPI flash, right?
2) Steps to load Linux kernel image to SPI flash.
U-Boot > mmcinfo
U-Boot > ext2load mmc 0:1 c0700000 /boot/uImage
u-Boot> sf probe 0
u-Boot> sf erase 0x100000 0x300000
u-Boot> sf write 0xC0700000 0x100000 0x26E3C8--> (size of uImage on MMC Card)
above command will load Linux Kernel to SPI flash, right?
3) Steps to load Linux file system in NAND (rootfs)
u-Boot> mw.b 0xC2000000 0xFF 0x06000000
u-Boot> ext2load mmc 0:1 C2000000 /media/mmcblk0p1/home/root/root_filesystem.jffs2
u-Boot> nand erase 0 0x8000000
u-Boot> nand write.jffs2 0xC2000000 0 0x05188000 --> (calculated size of .jffs2 file)
above command will load Linux File system to NAND flash, right?
4) Auto load kernel from SPI flash and file system from the NAND on power on.
U-Boot> setenv bootcmd "sf probe 0; sf read 0xc0700000 0x100000 0x300000;setenv bootargs mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mtdblock0 rw noatime rootfstype=jffs2 ip=off;bootm 0xc0700000"
U-Boot> saveenv
on restart,load kernel and filesystem from SPI flash and NAND Flash respectively and run automatically, right?
As currently, we are using MMC card to boot linux ,we setup environment with below command.We have connected serial port and giving commands from teraterm.
U-Boot > setenv bootargs mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mmcblk0p1 rw rootwait ip=off
//The response is as below
Loading file "/boot/uImage" from mmc device 0:1 (xxa1)
2548672 bytes read
U-Boot > bootm
  1. Booting kernel from Legacy Image at c0700000 ...
    Image Name: Linux-3.2.0+
    Data Size: 2548608 Bytes = 2.4 MB
    Load Address: c0008000
    Entry Point: c0008000
    Verifying Checksum ... OK
    Loading Kernel Image ... OK
    OK
Starting kernel ...
Linux version 3.2.0+ (mitydsp@vagrantup) (gcc version 4.5.4 20120305 (prerelease) (GCC) ) #1 PREEMPT Tue Jul 18 01:50:50 EDT 2017
Machine: MityDSP-L138/MityARM-1808
Ignoring unrecognised tag 0x42000101
DaVinci da850/omap-l138/am18x variant 0x1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 24384
Kernel command line: mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mmcblk0p1 rw rootwait ip=off
PID hash table entries: 512 (order: 1, 2048 bytes)
Memory: 96MB = 96MB total
Memory: 91328k/91328k available, 6976k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xc6800000 - 0xfea00000 ( 898 MB)
lowmem : 0xc0000000 - 0xc6000000 ( 96 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0536834 (5307 kB)
.init : 0xc0537000 - 0xc0560000 ( 164 kB)
.data : 0xc0560000 - 0xc05c00c0 ( 385 kB)
.bss : 0xc05c00e4 - 0xc05ecaf0 ( 179 kB)
NR_IRQS:245
Calibrating delay loop... 148.88 BogoMIPS (lpj=744448)
pid_max: default: 32768 minimum: 301
devtmpfs: initialized
DaVinci: 144 gpio irqs
print_constraints: dummy:
baseboard_pre_init: Entered
mityomapl138_setup_nand: using 8 bit data
baseboard_init [IndustrialIO]...
bio: create slab <bio-0> at 0
SCSI subsystem initialized
print_constraints: VDCDC1: 1150 <-
> 1350 mV at 1200 mV
print_constraints: VDCDC2: 1800 mV
print_constraints: VDCDC3: 1200 mV
print_constraints: LDO1: 1800 mV
print_constraints: LDO2: 2500 <--> 3300 mV at 3300 mV
Advanced Linux Sound Architecture Driver Version 1.0.24.
musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
musb-hdrc musb-hdrc: USB OTG mode controller at fee00000 using PIO, IRQ 58
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
RPC: Registered named UNIX socket transport module.
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 178
start plist test
end plist test
console [ttyS1] enabled
brd: module loaded
at24 1-0050: 256 byte 24c02 EEPROM, read-only, 0 bytes/write
MityOMAPL138: Found MAC = 40:d8:55:17:c7:d1
MityOMAPL138: Part Number = L138-FG-225-RC
ONFI flash detected
ONFI param page 0 valid
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron MT29F2G08ABAEAWP)
Bad block table found at page 131008, version 0x01
Bad block table found at page 130944, version 0x01
0x000008000000-0x000010000000 : "homefs"
spi_davinci spi_davinci.1: DMA: supported
spi_davinci spi_davinci.1: DMA: RX channel: 18, TX channel: 19, event queue: 0
m25p80 spi1.0: m25p64-nonjedec (8192 Kbytes)
Creating 8 MTD partitions on "m25p80":
0x000000000000-0x000000010000 : "ubl"
0x000000010000-0x000000090000 : "u-boot"
0x000000090000-0x0000000a0000 : "u-boot-env"
0x0000000a0000-0x0000000b0000 : "periph-config"
No LCD configured
MII PHY configured
0x0000000b0000-0x000000100000 : "reserved"
0x000000100000-0x000000400000 : "kernel"
0x000000400000-0x000000600000 : "fpga"
0x000000600000-0x000000800000 : "spare"
CAN device driver interface
mcp251x spi1.1: MCP251x didn't enter in conf mode after reset
mcp251x spi1.1: Probe failed
mcp251x spi1.1: probe failed
davinci_mdio davinci_mdio.0: davinci mdio revision 1.5
davinci_mdio davinci_mdio.0: no live phy, scanning all
davinci_mdio: probe of davinci_mdio.0 failed with error 5
ohci ohci.0: DA8xx OHCI
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
i2c /dev entries driver
cpuidle: using governor menu
usbhid: USB HID core driver
mmc0: new SDHC card at address 8eeb
mmcblk0: mmc0:8eeb SD04G 3.69 GiB
mmcblk0: p1
dsd1791 spi1.2: Failed to add route LLOUT
>Line Out
asoc: dsd1791 <-> davinci-mcasp.0 mapping ok
ALSA device list:
#0: MityDSP-L138 INDIO
TCP cubic registered
can: controller area network core (rev 20090105 abi 8)
NET: Registered protocol family 29
can: raw protocol (rev 20090105)
regulator_init_complete: LDO2: incomplete constraints, leaving on
regulator_init_complete: LDO1: incomplete constraints, leaving on
regulator_init_complete: VDCDC3: incomplete constraints, leaving on
regulator_init_complete: VDCDC2: incomplete constraints, leaving on
regulator_init_complete: VDCDC1: incomplete constraints, leaving on
console [netcon0] enabled
omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p1): using internal journal
EXT3-fs (mmcblk0p1): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:1.
devtmpfs: mounted
Freeing init memory: 164K
Failed to mount /sys/kernel/security: No such file or directory
Welcome to The Ångström Distribution!
NET: Registered protocol family 10
Starting LSB: The RPC portmapper...
Starting udev Coldplug all Devices...
Starting Remount API VFS...
Started Set Up Additional Binary Formats [ OK ]
Starting Debug File System...
Starting Journal Service...
Started Journal Service [ OK ]
Starting POSIX Message Queue File System...
Starting Apply Kernel Variables...
Started Huge Pages File System [ OK ]
Starting Load Kernel Modules...
Starting File System Check on Root Device...
Starting udev Kernel Device Manager...
Starting Temporary Directory...
Started LSB: The RPC portmapper [ OK ]
Started Remount API VFS [ OK ]
Started Debug File System [ OK ]
Started POSIX Message Queue File System [ OK ]
udevd1106: starting version 182
Started udev Kernel Device Manager [ OK ]
Started Apply Kernel Variables [ OK ]
Started Load Kernel Modules [ OK ]
Started File System Check on Root Device [ OK ]
Started Temporary Directory [ OK ]
Starting Remount Root FS...
Started FUSE Control File System [ OK ]
Started Configuration File System [ OK ]
Started Remount Root FS [ OK ]
Started Run pending postinsts [ OK ]
Starting Load Random Seed...
Starting Recreate Volatile Files and Directories...
Started Machine ID first boot configure [ OK ]
Started Load Random Seed [ OK ]
Started Recreate Volatile Files and Directories [ OK ]
Starting Restore Sound Card State...
Starting Timestamping service...
Started Timestamping service [ OK ]
Started SSH Key Generation [ OK ]
Starting Permit User Sessions...
Started Permit User Sessions [ OK ]
Started Restore Sound Card State [ OK ]
Starting Serial Getty on ttyS1...
Started Serial Getty on ttyS1 [ OK ]
.---O---. | | .-. o o | | |-----.-----.-----.| | .----..-----.-----. | | | __ | ---'| '--.| .-'| | | | | | | | |--- || --'| | | ' | | | |
The Angstrom Distribution mityomapl138 ttyS1
Angstrom v2012.05 - Kernel 3.2.0+
mityomapl138 login: Started udev Coldplug all Devices [ OK ]
Starting Networking...
PHY 0:03 not found
net eth0: could not connect to phy 0:03
ADDRCONF: eth0: link is not ready
portmap1079: Starting portmap daemon...
Started Networking [ OK ]
Starting DropBear SSH Server...
Started DropBear SSH Server [ OK ]
Starting Getty on tty1...
Started Getty on tty1 [ OK ]
mityomapl138 login:
5) In the above response, when the boot process reaches to line
we have to press any key to continue boot process , otherwise its waiting there for infinite time.As we are planning to run the system automatically without any user input, What is the solution for this problem?
6) The screen Prompts for mityomapl138 login:. We enter root login and it gives root@mityomapl138:~#. Then we give following commands to run our application. TestAdcDacRtARM and TestAdcDacRtDSP.out are our application generated file for ARM and DSP respectively.
root@mityomapl138:~# mount
root@mityomapl138:~# cp /media/mmcblk0p1/home/root/TestAdcDacRtARM /tmp/
root@mityomapl138:~# cp /media/mmcblk0p1/home/root/TestAdcDacRtDSP.out /tmp/
root@mityomapl138:~# insmod /lib/modules/$(uname -r)/extra/dsplinkk.ko
DSPLINK Module (1.65.00.03) created on Date: Jan 13 2014 Time: 16:10:29
root@mityomapl138:~# ./TestAdcDacRtARM TestAdcDacRtDSP.out
For auto run of application from the flash ,we can not enter mityomapl138 login:. could you please explain how to do above process in auto run of application with example?
As per my understanding I can write my application generated files to NAND flash with nand write command on uBoot prompt and read at RAM location with nand read command on uBoot prompt. Then How should I put command to auto run my application files from that RAM location?
6) which command I need to auto run below command to insert dsplink file?
Please advice to run all the program automatically without using serial port and any user input.
Thanks.
-Vivek
Replies (21)
RE: Auto run of application file (loaded in NAND Flash) - Added by Jonathan Cormier over 7 years ago
Vivek Ponnani wrote:
-- No Ethernet port
uBoot> sf probe 0
With this bootcmd, you will only load the fpga and nothing else on boot.
uBoot> saveenv
U-Boot > mmcinfo
u-Boot> sf probe 0
Yes
This path doesn't exist. /media/mmcblk0p1 is a mount in linux. /home/root/root_filesystem.jffs2 should work just fine.
Yes
U-Boot> saveenv
Yes, though you've now overridden your fpga load. You need to add sf read 0xc0700000 0x580000 0x80000; loadfpga 0xc0700000; back in after the sf probe.
As currently, we are using MMC card to boot linux, we setup environment with below command.We have connected serial port and giving commands from teraterm.
That should be the end of the boot process. What do you expect to happen after this?
This path /media/mmcblk0p1/home/root/TestAdcDacRtARM is the same as /home/root/TestAdcDacRtARM.
Why do you copy these files to temp?
You are running them from /home/root/ here.
You need to create a bash script which calls those commands. And then you can use systemd to run the script on boot.
https://www.devdungeon.com/content/creating-systemd-service-files
bash script "start_application.sh"
#!/bin/sh
The ARM application you have written requires linux to be running so you can't launch it from u-boot. Similarly the dsp application is likely relying on dsplink which also requires linux.
You would run this command from your bash script on boot. See above comment.
Thanks.
-Vivek
RE: Auto run of application file (loaded in NAND Flash) - Added by Vivek Ponnani about 7 years ago
Thanks for your response. It is very helpful.
Most of the points are cleared. I have further queries as below.
1) I am not much familiar with linux.I tried to create AutoRun.service file in /etc/systemd/system folder as per the link https://www.devdungeon.com/content/creating-systemd-service-files. please take a look and suggest if any changes required. I belive this .service file will be called automatically after end of boot process. Or we have to do something to call it after boot process?
AutoRun.service file is as below.
[Unit]
Description=Application run
After=network.target
[Service]
WorkingDirectory=/home/root
ExecStart=/bin/start_application.sh
Restart=always
[Install]
WantedBy=multi-user.target
2) In which folder I have to create start_application.sh? As in bin folder, create document is not allowed. According to start_application.sh path I have to change the path in ExecStart of AutoRun.service file?
3) once I copy the TestAdcDacRtARM (Arm application) and TestAdcDacRtDsp.out to NAND flash (in memory region from 0x8000000 to 0xFFFFFFF defined as (userfs) in setenv command) with nand write command, and run
from the start_application.sh.
Will it run directly from that NAND flash memory location or I have to copy that files to RAM (DDR2)?
Or there is some another process to load application files (TestAdcDacRtARM and TestAdcDacRtDsp.out) on the board?
4) I belive once we load all the required programs in SPI Flash and NAND flash, then after uBoot it will count down from 3 to 0 as bootdelay =3. If we want to load any program again in flash after uBoot, we have to hit any key between count 3 to 0, is that correct?
Thanks
-Vivek.
RE: Auto run of application file (loaded in NAND Flash) - Added by Jonathan Cormier about 7 years ago
[Unit]
[Service]
Restart=always
[Install]
Your missing type=simple.
[Unit]
[Service]
Type=simple
Restart=always
[Install]
  • Then you'll want to reload the systemd daemon
    systemctl daemon-reload
  • Test your service
    systemctl start AutoRun.service
    systemctl status AutoRun.service
    The status command should report that the service is running.
  • And enable the service so it starts on boot
    systemctl enable AutoRun.service
  • Reboot and verify that the service started
    reboot
You can put it pretty much any place. /bin would be okay. Though we usually put them in /home/root/ so that all the files are in one place.
I'm not sure what you mean.
Yes the ExecStart= should point to where you place the start_application.sh file.
Okay so we don't want or need to write these files directly to the nand. We want them stored on a filesystem so they can be easily read by linux. Generally during development if we boot from the nand we copy the programs over the ethernet. Since you don't have that I'd suggest copying them from mmc or from a usb flash drive.
There is no need to manually copy your program to ram if its stored in the filesystem. It will simply appear as a file and can be executed normally.
Tweaking your code from before, this will copy the files from the mmc /home/root to the nand /home/root.
root@mityomapl138:~# cp /media/mmcblk0p1/home/root/TestAdcDacRtARM /home/root/
root@mityomapl138:~# cp /media/mmcblk0p1/home/root/TestAdcDacRtDSP.out /home/root/
Yes, you can break into u-boot by pressing any key during this window of time.
Thanks
-Vivek.
[Unit]
[Service]
Restart=always
[Install]
  • Test your service
    reboot
could you please explain where (on board or VM) and when (if command execution is on board)to give all this systemctl commands? I have created AutoRun.service file in the folder from where I will generate .jffs2 file for linux filesytem.
Thanks
-Vivek.
[Unit]
[Service]
Restart=always
[Install]
  • Test your service
    reboot
All of these commands were assuming you were booted and running on the l138.
Alright so assuming your trying to customize the MDK mityomap-full.tgz filesystem. We extract the filesystem, copy your application files to home/root. Copy your systemd service file to etc/systemd/system and create the symlink which will "enable" the service.
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs$ ls
mityomap-base.jffs2  mityomap-base.tgz  mityomap-full.jffs2  mityomap-full.tgz
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs$ mkdir mityomap-full
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs$ cd mityomap-full
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs/mityomap-full$ sudo tar xzf ../mityomap-full.tgz
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs/mityomap-full$ ls
bin  boot  dev  etc  home  lib  media  mnt  proc  run  sbin  sys  tmp  usr  var
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs/mityomap-full$ sudo cp <PATH>/TestAdcDacRtARM <PATH>/TestAdcDacRtDsp.out <PATH>/start_application.sh home/root/
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs/mityomap-full$ sudo cp ~/AutoRun.service etc/systemd/system/
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs/mityomap-full$ sudo ln -s /etc/systemd/system/AutoRun.service etc/systemd/system/multi-user.target.wants/
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs/mityomap-full$ sudo ls -la etc/systemd/system/multi-user.target.wants/
total 12
drwxr-sr-x 1 root root 100 Jan 24 14:36 ./
drwx--S--- 1 root root 240 Aug  9  2012 ../
lrwxrwxrwx 1 root root  35 Jan 24 14:36 AutoRun.service -> /etc/systemd/system/AutoRun.service
lrwxrwxrwx 1 root root  39 Jan 13  2014 dropbearkey.service -> /lib/systemd/system/dropbearkey.service
lrwxrwxrwx 1 root root  36 Jan 13  2014 remote-fs.target -> /lib/systemd/system/remote-fs.target
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs/mityomap-full$ sudo tar czf ../mityomap-full-Vivek-20180124.tgz *
jcormier@jcormier-desktop:~/MDK_2014-01-13/fs$ sudo mkfs.jffs2 -x lzo --root=mityomap-full/ --faketime --output=mityomap-full-Vivek-20180124.jffs2 --little-endian --eraseblock=0x20000 -n
mityomap-base.jffs2  mityomap-full.jffs2                 mityomap-full-Vivek-20180124.tgz
mityomap-base.tgz    mityomap-full.tgz
mityomap-full        mityomap-full-Vivek-20180124.jffs2
I recommend once you've verified your customized image works to take the .jffs2 and .tgz files and commit them to revision control or similar.
I followed the suggestions and tried to boot from flash. But It still does not run application automatically. Below is my setup on the board.
1) environment setting on board.
U-Boot > printenv
bootdelay=3
baudrate=115200
bootfile="uImage"
flashubl=tftp 0xc0700000 mityomap/UBL_SPI_MEM.ais; sf probe 0; sf erase 0 0x10000; sf write 0xc0700000 0 0x10000
flashrootfs=tftp 0xc2000000 mityomap/mityomap-base-mityomapl138.jffs2; nand erase 0 0x08000000; nand write.jffs2 0xc2000000 0 ${filesize}
serverip=10.0.0.23
autoload=no
mtdids=nand0=nand
filesize=71544
programfpga=sf probe 0;sf read 0xc0700000 0x580000 0x80000; loadfpga 0xc0700000
stdin=serial
stdout=serial
stderr=serial
ethaddr=40:d8:55:17:c8:1c
ver=U-Boot 2009.11-00002-gc6adda5 (May 01 2015 - 11:42:37)
bootcmd=run programfpga;sf read 0xc0700000 0x100000 0x300000;bootm 0xc0700000
bootargs=mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mtdblock0 rw, noatime rootfstype=jffs2 ip=off
Environment size: 1226/65532 bytes
U-Boot > saveenv
Saving Environment to SPI Flash...
Erasing SPI flash...Writing to SPI flash...done
2) FPGA write in SPI Flash
U-Boot > sf erase 0x580000 0x80000
U-Boot > sf write 0xC0700000 0x580000 0x00071544
U-Boot > setenv programfpga "sf probe 0;sf read 0xc0700000 0x580000 0x80000; loadfpga 0xc0700000"
U-Boot > setenv bootcmd "run programfpga"
U-Boot > saveenv
3)Kernel write in SPI flash and filesystem in NAND.
2548680 bytes read
U-Boot > sf probe 0
U-Boot > sf erase 0x100000 0x300000
U-Boot > sf write 0xC0700000 0x100000 0x26E3C8
U-Boot > mw.b 0xC2000000 0xFF 0x06000000
U-Boot > ext2load mmc 0:1 0xC2000000 /home/root/mityomap-full-custom.jffs2
Loading file "/home/root/mityomap-full-custom.jffs2" from mmc device 0:1 (xxa1)
86608080 bytes read
U-Boot > nand erase 0 0x8000000
NAND erase: device 0 offset 0x0, size 0x8000000
Erasing at 0x7fe0000 -- 100% complete.
OK
U-Boot > nand write.jffs2 0xC2000000 0 0x5299000
NAND write: device 0 offset 0x0, size 0x5299000
86609920 bytes written: OK
4) Response on board restart after all setting done..
U-Boot > OMAP-L138/AM-1808/AM-1810 initialization passed!
Configuring 128MB mDDR
Booting TI User Boot Loader
UBL Flashtype: SPI
Starting SPI Memory Copy...
DONE
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
ARM Clock : 300000000 Hz
DDR Clock : 150000000 Hz
EMIFA CLock : 100000000 Hz
DSP Clock : 300000000 Hz
ASYNC3 Clock : 150000000 Hz
Enet config : 2
MMC 0 Enable : 1
Resetting ethernet phy
Net: No ETH PHY detected!!!
Loading FPGA from 0xC0700000 with 0x80000 bytes
Loading FPGA done
    Data Size: 2548616 Bytes = 2.4 MB
    OK
Starting kernel ...
Linux version 3.2.0+ (mitydsp@vagrantup) (gcc version 4.5.4 20120305 (prerelease) (GCC) ) #1 PREEMPT Tue Jul 11 06:29:07 EDT 2017
Kernel command line: mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mtdblock0 rw, noatime rootfstype=jffs2 ip=off
NR_IRQS:245
> 1350 mV at 1200 mV
TCP reno registered
start plist test
end plist test
brd: module loaded
MityOMAPL138: Found MAC = 40:d8:55:17:c8:1c
ONFI flash detected
No LCD configured
MII PHY configured
>Line Out
ALSA device list:
mmcblk0: p1
VFS: Mounted root (jffs2 filesystem) on device 31:0.
devtmpfs: mounted
udevd1090: starting version 182
Starting Run pending postinsts...
EXT3-fs (mmcblk0): error: can't find ext3 filesystem on dev mmcblk0.
EXT2-fs (mmcblk0): error: can't find an ext2 filesystem on dev mmcblk0.
FAT-fs (mmcblk0): bogus number of reserved sectors
FAT-fs (mmcblk0): Can't find a valid FAT filesystem
VFS: Can't find a Minix filesystem V1 | V2 | V3 on device mmcblk0.
cramfs: wrong magic
EXT3-fs (mmcblk0p1): 1 orphan inode deleted
EXT3-fs (mmcblk0p1): recovery complete
Disabling lock debugging due to kernel taint
PHY 0:03 not found
mityomapl138 login:
Why it is looking for ext3 file system and asking for login? I am expecting to run system as I have start_application.sh in /home/boot folder and AutoRun.service in /etc/systemd/system. Is there any setting which I have missed? should I remove memory card from board while booting from flash? Please suggest.
5) Below is the setting for config set on uBoot, when we use MMC card for booting the system.
U-Boot > config set
Ethernet Config : 2 (make it 0 for Ethernet port)
UART - 0 Configuration ---
Enable UART : 0
UART - 1 Configuration ---
Enable UART : 1
Baud : 115200
HW Flow Control : 0
Is Console : 1
UART - 2 Configuration ---
Enable UART : 0
SPI - 0 Configuration ---
Enable SPI : 0
SPI - 1 Configuration ---
Enable SPI : 1
CLK is Output : 1
Chip Select [0] Enable : 01
Chip Select [1] Enable : 00
Chip Select [2] Enable : 00
Chip Select [3] Enable : 00
Chip Select [4] Enable : 00
Chip Select [5] Enable : 00
Chip Select [6] Enable : 00
Chip Select [7] Enable : 00
ENA ENable : 0
CLK Rate : 30000000
LCD Configuration
LCD Enable : 1
Panel Name : wvga_800x480
MMC 0 Configuration
MMC 0 Enable : 1
Write Protect Pin bank : 4
Write Protect Pin bank offset : 1
Card Detect Pin bank : 4
Card Detect Pin bank offset : 0
U-Boot > config save
We need to change any setting in above configuration when we boot from SPI flash?
Thanks.
Vivek.
What does your application do? How do you know its running?
There should not be a comma after rw. This isn't breaking anything though.
You appear to have set bootcmd to "bootcmd=run programfpga;sf read 0xc0700000 0x100000 0x300000;bootm 0xc0700000" but its not in your log.
Looks good
root= is set to the nand device so we are booting from nand not sdcard.
cramfs: wrong magic
The system is trying to mount the bare mmc device so its failing each of the types its trying. This isn't a problem.
It finally found a filesystem on partition 1 of the mmc. Still not a problem.
One of the boot scripts is setup to look for and try to mount the sd card. This shouldn't be a problem.
Getty is setup to start on boot, its job is to ask for a login. This seems normal and fine to me. Is your application supposed to interact with the debug console?
Login and check to see if the files you added are there.
Post the results for the following.
ls -la /home/root/
ls -la /etc/systemd/system/*
# Test your service
# The status command should report that the service is running.
# And enable the service so it starts on boot
Shouldn't matter.
Nope you are booting from nand just fine.
--Our application does demodulation. At the start of the application we should get following debug on teraterm.
root@mityomapl138:~# ./DigitalDemodulatorARM DigitalDemodulatorDSP.out
spi mode: 0
bits per word: 8
max speed: 10000000 Hz (10000 KHz)
Creating DSPApp object.
Loading file DigitalDemodulatorDSP.out
PROC Load successful
Starting application.
DSP Initialization finished."
Sending a message to the DSP to start receive.
Waiting for DSP response (type 'q' to quit)...
[DSP] getting instance of DSPuPP
[DSP] configuring UPP
[DSP] upp configured
-- ok
--Actully bootcmd is in printenv command (1st point). I did it after FPGA write in flash.. by mistake I mentioned in 1st point. It should be last point.
In FPGA programming, I believe as soon as FPGA programming done with above command ,the FPGA done LED should be illuminated and FPGA should start running. But No LED illuminated after above commands whereas when we program FPGA with JTAG it works.
Looks good
--ok
-- yes we want to boot from NAND ony.
cramfs: wrong magic
--No,our application is not supposed to interact with the debug console. We don't want any connection with any host system. We want that our application should start and run without any interact with the debug console. For that we want to bypass login. And also after
we need to press any key for the login prompt on host machine which connected to board with serial port. Otherwise it wait there for infinite time. what could be the solution for it?
--Attached Result.txt
Shouldn't matter.
------some Observation from the debug on console highlighted with bold
portmap1099: Starting portmap daemon...
Started D-Bus System Message Bus [ OK ]
mityomapl138 login: Disabling lock debugging due to kernel taint
cramfs: wrong magic
Started Login Service [ OK ]
Started Avahi mDNS/DNS-SD Stack [ OK ]
PHY 0:03 not found
mityomapl138 login:
From the debug on the console, It seems AutoRun.service is called immediately after
As I can see there is debug on console
which is for the 1st command - insmod /lib/modules/$(uname -r)/extra/dsplinkk.ko - in start_application.sh.
Then it looks for MMC card and after it stops at
Thereafter I have to press any key and it asks for login.
Should I change After = network.target,in AutoRun.Service file to something else where actually boot process stops?
[Unit]
[Service]
Type=simple
Restart=always
[Install]
Thanks.
-Vivek.
Yes I believe the FPGA light should come on. I'm not familiar with the FPGA but if the light doesn't come on then it probably wasn't programmed with a correct image.
Okay and it looks like thats working.
Okay I'm not sure if we are understanding each other. From your example output above, your app asks for a 'q' key to be pressed to quit. Does your app need user input?
I'm not sure what you mean by this.
You should not have to press any key or login. The app will run in the background. The device is finished booting when this happens.
These results look good. Everything appears to be running. I'm confused about what is not working.
It stops because everything has finished booting. And your application is running.
After network.target seems to work. I'm unclear what you expect to happen.
I was expecting following Debug response, which comes up when I run application by myself with the help of treaterm and booting off from MMC card.
--response
spi mode: 0
bits per word: 8
1)When application runs,there is some debug part (as above)which dsp sends to arm with dsplink. It should be there on the screen even application runs automatically on boot,right?
2) pressing q is for terminating the application. We will bypass it. But there is no need of any input to start and run the application.
Thanks
-Vivek.
Generally when auto running things on linux the output isn't shown on the debug console. With the .service files, any output your app sends gets captured in the journal which can be displayed by journalctl command. However we don't have a lot of experience using this tool. What we usually do is redirect program output to a log file which you can then open if you want to see what the program is doing.
So your start script would do the following which would create a log file in the home directory.
./DigitalDemodulatorARM DigitalDemodulatorDSP.out >> ~/app.log 2>&1
See the following link for details
https://www.tldp.org/LDP/abs/html/io-redirection.html
Note if you want to see live updates to the log file you can then run tail -f ~/app.log which will open the file and print new output as the file changes.
Okay.
Okay.
Thanks a lot Jonathan. There was a problem in .bin file generation of FPGA. With the help from the FPGA forum , we are able to solve it. Now our application is running from flash. Thanks for all your support and guidance.
Apart from this, one more thing I want to understand.
Currently our application program is part of .jffs2 file system (Linux root file system + application program) in NAND (rootfs). But if we want to update only application every time in userfs part of NAND and not with .jffs2 which is part of the rootfs of NAND then what should we do?
Thanks
-Vivek.
I'm not sure what your requirements are for updates but I'll answer with what we normally due although there are more options.
Normally there is no need to replace the whole filesystem in order to do an update. What we've done in the past is to have the start script check for an update and if present, it will replace the needed files and then run the updated application. This update could be provided over the network or on an attached USB or sdcard.
The userfs partition is usually used if the system requires some more robustness. The root partition can be mounted read-only and then data that is collected gets stored on the read-write userfs partition. You might still store your application on the read-only partition in this case to ensure it doesn't get overwritten or corrupted, and the update process can remount the root partition read-write during the update.
RE: Auto run of application file (loaded in NAND Flash) - Added by Vivek Ponnani over 6 years ago
[Unit]
[Service]
Restart=always
[Install]
  • Test your service
    reboot
As per previous disscussion, I was able to make mityomap-full-custom.tgz and mityomap-full-custom.jffs2 file and able to run it on the board. Now I want to update my application file and want to make new .jffs2 file as I have no other mechanism to upgrade my application file. For that I followed below procedure , but it is not updating my application file as when I try to run my application on board, it gives me result of previous application file. So, it seems my new .jffs2 system is not updating.
steps to make new jffs2 for application update only. My previous mityomap-full-custom.tgz file is in /home/mitydsp folder.
1)mitydsp@vagrantup:~/mkdir mityomap-full
2)mitydsp@vagrantup:~/cd mityomap-full
3)mitydsp@vagrantup:~/mityomap-full$ sudo tar xzvf /home/mitydsp/mityomap-full-custom.tgz
above command extract folders/files of mityomap-full-custom.tgz (compressed archive) file into mityomap-full folder. We need to update only application file, so take previous copy of .tgz file , unzip it.
4) to copy new generated application files to mityomap-full folder.
mitydsp@vagrantup:~$ sudo cp /home/mitydsp/DigitalDemodulatorARM /home/mitydsp/mityomap-full/home/root
mitydsp@vagrantup:~$ sudo cp /home/mitydsp/DigitalDemodulatorDSP.out /home/mitydsp/mityomap-full/home/root
5)mitydsp@vagrantup:~/mityomap-full$ sudo tar czvf ../mityomap-full-custom.tgz *
above command creates a tar(zip) archive of a subdirectory in /home/mitydsp folder
6) mitydsp@vagrantup:~$ sudo mkfs.jffs2 -x lzo --root=mityomap-full/ --faketime --output=mityomap-full-custom.jffs2 --little-endian --eraseblock=0x20000 -n
above command will create .jffs2 file to copy in the board.
7) Copy mityomap-full-custom.jffs2 from VM to SD card.
mitydsp@vagrantup:~$ sudo cp /home/mitydsp/mityomap-full-custom.jffs2 /media/mitydsp/rootfs/home/root/
on Board
- Steps to load Linux kernel image to SPI flash.
U-Boot > mmcinfo
u-Boot> sf probe 0
- Steps to load .jffs2 to NAND flash.
u-Boot> ext2load mmc 0:1 0xC2000000 /home/root/mityomap-full-custom.jffs2
u-Boot> nand write.jffs2 0xC2000000 0 0x5299000--> (calculated size of .jffs2 file)
u-Boot>setenv bootargs mem=96M console=ttyS1,115200n8 mtdparts=nand:128M(rootfs),-(userfs) root=/dev/mtdblock0 rw, noatime rootfstype=jffs2 ip=off
uBoot> setenv programfpga "sf probe 0;sf read 0xc0700000 0x580000 0x80000; loadfpga 0xc0700000"
U-Boot> setenv bootcmd "run programfpga;sf read 0xc0700000 0x100000 0x300000;bootm 0xc0700000"
U-Boot> saveenv
If I check new mityomap-full-custom.tgz file, in /home/root folder it shows DigitialDemodulatorARM and DigitalDemodulatorDSP.out updated on VM. Still when I start the board, it runs old application.
Please suggest , If I am missing something in this process or any command is wrong?
Vivek.
RE: Auto run of application file (loaded in NAND Flash) - Added by Jonathan Cormier over 6 years ago
I don't see any problems with your procedure. Although you don't mention running sync or safely unmounting your sd card. I know not doing this has been a problem for me in the past.
Unrelated: Remove comma so its just "rw noatime" with space
rw, noatime
Although you don't mention running sync or safely unmounting your sd card - this comment is related to virtual machine or on board?
From virtual machine, we always safely eject the card and then remove. What is running sync?
And once we copy .jffs2 file from the card to flash, we do not need the card.
On the virtual machine
sync is a commandline tool which causes all data to be synced to disk. It is what "Safely eject" does in the background.
Correct, once you write the .jffs2 file to flash, you don't need the sdcard anymore.
I'm not sure whats going wrong. What your doing should work. Double check that you are copying the files you think you are. Possibly delete the old copies and recreate them so you can be sure they were updated/copied correctly.
I rechecked the files which I wanted to copy, deleted old copies and recreate them but same result. I tried to run start_application.sh file manually on board, then it gives results as below.
root@mityomapl138:~# start_application
sh: start_application: not found
root@mityomapl138:~# ls -ls
208 -rwxr-xr-x 1 root root 213102 Jan 1 1970 DigitalDemodulatorARM
1000 -rwxr-xr-x 1 root root 1023695 Jan 1 1970 DigitalDemodulatorDSP.out
0 -rw-r--r-
1 root root 0 Jan 1 00:01 results.dat
0 -rwxr-xr-x 1 root root 112 Jan 1 1970 start_application.sh
root@mityomapl138:~# ./start_application.sh
insmod: error inserting '/lib/modules/3.2.0+/extra/dsplinkk.ko': -1 File exists
spi mode: 0
bits per word: 8
Error running MSGQ_transportOpen : 0x80008028
Msqg <GPPMSGQ1> open failure: 0x80008050
FAILED to CONNECT TO OUTBOUND: name: DSPMSGQ0, status: 0x8000802d
inbound:GPPMSGQ1: Status = 0x8000800b
inbound:GPPMSGQ1: Terminating
It seems, the link between ARM and DSP is not working. When everything is working the message PROC Load successful comes instead of Error running MSGQ_transportOpen : 0x80008028. But when the same program we were running from card before, it was working ok.
Vivek
Sounds like you might have a program error.
Note: If you want to verify if the file is the same one from your VM you can calculate an md5sum. And compare.
 $ md5sum results.txt
b248dba5974f60d376be608222f6d0af  results.txt
Actually we disabled AutoRun.service (systemctl disable AutoRun.service) on board because we wanted to test further with new application generated files and we wanted to test it directly from MMC card. If we keep AutoRun.service enabled, it starts running the application which was stored in NAND and we were not able to access MMC card to test new generated application files.
So, I again tried to disable AutoRun.service (systemctl disable AutoRun.service) on board and directly run start_application.sh after login.
root@mityomapl138:~# systemctl disable AutoRun.service
This works perfectly ok. I mean it runs my new application file which I copied to NAND with new .jffs2 file.
Now , I enable AutoRun.service as below.
root@mityomapl138:~#systemctl daemon-reload
root@mityomapl138:~# systemctl start AutoRun.service
root@mityomapl138:~#systemctl status AutoRun.service
root@mityomapl138:~# systemctl enable AutoRun.service
Then I reboot the system. It runs program with AutoRun.service and it shows my previous application file result. And then if I run start_application.sh, it shows the result which I posted earlier in my previous post.
spi mode: 0
bits per word: 8
I think because the one application is already running.
So, now my question is, the way I am enabling AutoRun.service is the correct way or I have to follow some different procedure. should I again generate .jffs2 with following procedure, which copies AutoRun.service to etc/systemd/system/ folder?
mitydsp@vagrantup:~$sudo cp AutoRun.service etc/systemd/system/
mitydsp@vagrantup:~$ sudo ln -s /etc/systemd/system/AutoRun.service etc/systemd/system/multi-user.target.wants/
mitydsp@vagrantup:~$ sudo ls -la etc/systemd/system/multi-user.target.wants/
Because by enabling AutoRun.service it runs previous application.
Vivek.
I thought your new application files were programmed to the nand?
ok
So your saying the AutoRun service is starting your old application? Where is it finding the old application?
spi mode: 0
bits per word: 8
Makes sense
You said you manually disabled the service above. And then manually re-enabled it. And that it was starting the wrong application. It seems like the service is running just fine.
But how can it run the old application, I thought you overwrote it?
    (1-21/21)
