Cannot install the GCC Toolchain for Angström
Added by Okan Çalış almost 8 years ago
I'm using MityDsp L138F, and I'm trying to load a simple program to the ARM core running Linux, as documented here: https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Starter_Guide
I have an Ubuntu 16.04 virtual machine installed on a Windows host, but I can't install the GCC toolchain, as explained here: https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/GCC_Toolchain
When I run the executable by typing ./usr/local/oecore-i686/environment-setup-armv5te-angstrom-linux-gnueabi, it doesn't return any errors; however, if I type arm-angstrom-linux-gnueabi-gcc -v to verify the installation, the terminal prints arm-angstrom-linux-gnueabi-gcc: command not found.
I'm trying to install "Aug-2012 SDK Tarball 64-Bit" from https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/GCC_Toolchain
What could the problem be?
Replies (9)
RE: Cannot install the GCC Toolchain for Angström - Added by Michael Williamson almost 8 years ago
[edited, you did run the setup script]
This command adds the path to the cross compiler tools to your shell. If you type "arm-" and hit the tab key twice you should see multiple gcc related commands appear after running the setup script.
RE: Cannot install the GCC Toolchain for Angström - Added by Okan Çalış almost 8 years ago
Hi Mike,
Thanks for your response. After running the script, I tried typing "arm-", but it doesn't show me anything if I double press the Tab key.
If you run the command:
find /usr/local/oecore-i686 | grep arm
Do you see anything?
If I run find /usr/local/oecore-i686 | grep arm, it returns "find: 'usr/local/oecore-i686': No such file or directory".
But when I run, find /usr/local/oecore-x86_64 | grep arm, it returns a long list of files, most of which are header files.
I don't have an oecore-i686 directory, probably because I downloaded the 64-bit version.
RE: Cannot install the GCC Toolchain for Angström - Added by Jonathan Cormier almost 8 years ago
There is supposed to be a space between the . and the /usr part of the path. The '.' is the same as the 'source' command which causes the shell to run the script in the current shell environment. Thus allowing the PATH variable to be updated.
I honestly didn't know '.' was actually a command there. Thank you.
arm-angstrom-linux-gnueabi-gcc -v returns the following:
Using built-in specs.
COLLECT_GCC=arm-angstrom-linux-gnueabi-gcc
COLLECT_LTO_WRAPPER=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/armv5te-angstrom-linux-gnueabi/gcc/arm-angstrom-linux-gnueabi/4.5.4/lto-wrapper
Target: arm-angstrom-linux-gnueabi
Configured with: /space/projects/oe/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/work-shared/gcc-4.5-r49+svnr184907/gcc-4_5-branch/configure --build=x86_64-linux --host=x86_64-angstromsdk-linux --target=arm-angstrom-linux-gnueabi --prefix=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr --exec_prefix=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr --bindir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/armv5te-angstrom-linux-gnueabi --sbindir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/bin/armv5te-angstrom-linux-gnueabi --libexecdir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/libexec/armv5te-angstrom-linux-gnueabi --datadir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/share --sysconfdir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/etc --sharedstatedir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/com --localstatedir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/var --libdir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/lib/armv5te-angstrom-linux-gnueabi --includedir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/include --oldincludedir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/include --infodir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/share/info --mandir=/usr/local/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/usr/share/man --disable-silent-rules --disable-dependency-tracking --with-libtool-sysroot=/space/projects/oe/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/sysroots/x86_64-nativesdk-angstromsdk-linux --with-gnu-ld --enable-shared --enable-languages=c,c++ --enable-threads=posix --disable-multilib --enable-c99 --enable-long-long --enable-symvers=gnu --enable-libstdcxx-pch --program-prefix=arm-angstrom-linux-gnueabi- --enable-target-optspace --enable-lto --enable-libssp --disable-bootstrap --disable-libgomp --disable-libmudflap --with-linker-hash-style=gnu --with-ppl=no --with-cloog=no --enable-cheaders=c_global --with-float=soft --with-local-prefix=/usr/local/oecore-x86_64/sysroots/armv5te-angstrom-linux-gnueabi/usr --with-gxx-include-dir=/usr/local/oecore-x86_64/sysroots/armv5te-angstrom-linux-gnueabi/usr/include/c++ --with-build-time-tools=/space/projects/oe/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/sysroots/x86_64-linux/usr/arm-angstrom-linux-gnueabi/bin --with-sysroot=/usr/local/oecore-x86_64/sysroots/armv5te-angstrom-linux-gnueabi --with-build-sysroot=/space/projects/oe/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/sysroots/mityomapl138 --disable-libunwind-exceptions --disable-libssp --disable-libgomp --disable-libmudflap --with-mpfr=/space/projects/oe/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/sysroots/x86_64-nativesdk-angstromsdk-linux --with-mpc=/space/projects/oe/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/sysroots/x86_64-nativesdk-angstromsdk-linux --enable-nls --enable-__cxa_atexit
Thread model: posix
gcc version 4.5.4 20120305 (prerelease) (GCC)
No worries its a bit obscure. We should probably switch to documenting as 'source /usr/local/oecore-i686/environment-setup-armv5te-angstrom-linux-gnueabi' to make it more clear.
RE: Cannot install the GCC Toolchain for Angström - Added by VIDYA J about 6 years ago
I am also facing same problem, ./usr/local/oecore-i686/environment-setup-armv5te-angstrom-linux-gnueabi, is not giving any response
RE: Cannot install the GCC Toolchain for Angström - Added by Jonathan Cormier about 6 years ago
Please try source /usr/local/oecore-i686/environment-setup-armv5te-angstrom-linux-gnueabi
Note this doesn't print anything when you run it.
    (1-9/9)
