JPNet: No ETH PHY detected!!!
Added by Jordi Perez Serra over 12 years ago
I have a mitydspl138 board. I accidentally overwrote some of the u-boot memory. I used the serial programmer to re-flash u-boot
https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Reprogramming_a_Dead_Board
But now I get this error message on bootup.
Enet config : 0
I have checked and the version of u-boot and UBL are the same as before the incident
I have tried using the older versions provided by CritialLink and compiling my own new ones but with no difference.
Additionally:
Running mii device responds with nothing.
U-Boot > mii device
MII devices:
U-Boot >
'mii info' and 'mii info 3' spams 'NULL device name!' at me.
I also noticed that the config item 'Ethernet Config' is set to 0 when it should be set to 1 or 2. I tried following the instructions here https://support.criticallink.com/redmine/projects/arm9-platforms/wiki/Network_configuration
But I cannot change the value from 0. I'm not sure if this setting is the cause or just a victim of the problem.
Thank you for any help.
JP RE: Net: No ETH PHY detected!!! - Added by Jordi Perez Serra over 12 years ago
I used the serial flashing program to erase the memory before flashing u-boot again and this time phy eth is detected and networking works normally.
I'm sorry for the trouble.
