CRDebugging DSP-App when DSPLink is running
Added by Christian Rückl about 13 years ago
Hi all,
what is the usual procedure for debugging the DSP-App when using the DSPLink?
Based on the DSPLink example, out from the wiki, I developed an DSP-App where the functions are controlled by the ARM-App.
I know that I can debug the DSP-App standalone (with disabled DSPLink) and I also read that I can debug the ARM-App with a gdb-server and eclipse.
Is there any posibility to debug both apps at the same time?
Thanks for all the answers!
Christian
GG RE: Debugging DSP-App when DSPLink is running - Added by Gregory Gluszek about 13 years ago
Hi Christian,
See the last section of http://support.criticallink.com/redmine/projects/arm9-platforms/wiki/DSP_Quick_Start for details on how we debug a DSP application that has been loaded by the ARM via DSPLink. I do not have much experience with gdb-server and am not sure if that will play nice with this method so that you can debug both the DSP and ARM at the same time, but it sounds like it might work.
Please let us know if this helps.
\Greg
