Project build in CCSv5.1 not successful when using the Platform.tci for creating a DSP/BIOS 5.x Configuration File
Added by Christian Rückl almost 13 years ago
to getting started with the C674x-Core, CCSv5.1 and DSP/BIOS, I generated a new DSP/BIOS-Project in the CCS. I chose a sample application which is already provided by TI and was selectable in the set up screen for a new project.
I chose the following Device-options:
- Family: C6000
- Variant: Generic devices
- Generic C674x Device
The compiler version is "TI v7.3.1"
Output format: legacy COFF
DSP/BIOS version: 5.41.11.38
When I build this project with the orignial generated *.tcf-file, it works!
Whem I'm creating a DSP/BIOS 5.x Configuration File by using the "Platform.tci" from the actual MDK (03/12/2012), the building process stops with a lot of errors.
I didn't forgot to instert the path of the Platform.tci-fileinto the "TConf Script Compiler->General Options->Configuration import path".
I did also the DSP_Hello_World tutorial and stoped at the same point then now.
Can anybody help me and telling me what i'm doing wrong?
Br,
Christian
Replies (5)
RE: Project build in CCSv5.1 not successful when using the Platform.tci for creating a DSP/BIOS 5.x Configuration File - Added by Christian Rückl almost 13 years ago
there are really a lot of errors - more than 100 but i will post here all i got:
Description Resource Path Location Type
./hellobios5cfg.cmd CACHE_L1D memory range has already been hellobios5 line 260 C/C++ Problem
./hellobios5cfg.cmd CACHE_L1D memory range overlaps hellobios5 line 260 C/C++ Problem
./hellobios5cfg.cmd CACHE_L1P memory range has already been hellobios5 line 259 C/C++ Problem
./hellobios5cfg.cmd CACHE_L1P memory range overlaps hellobios5 line 259 C/C++ Problem
./hellobios5cfg.cmd CACHE_L2 memory range overlaps existing hellobios5 line 258 C/C++ Problem
./hellobios5cfg.cmd DDR memory range has already been hellobios5 line 261 C/C++ Problem
./hellobios5cfg.cmd IRAM memory range has already been hellobios5 line 262 C/C++ Problem
./hellobios5cfg.cmd IRAM memory range overlaps existing hellobios5 line 262 C/C++ Problem
./hellobios5cfg.cmd L3_CBA_RAM memory range has already hellobios5 line 263 C/C++ Problem
./hellobios5cfg.cmd L3_CBA_RAM memory range overlaps hellobios5 line 263 C/C++ Problem
#10056 symbol "_BIOS_init" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "_BIOS_start" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "_MEM_memtab" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "_RTDX_Buffer_End" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "_RTDX_Buffer_Start" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "_RTDX_Buffer" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "BIOS_init" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "BIOS_start" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "BIOS$$CLKOFF" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "BIOS$$CLKON" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "CLK_INTBIT" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "CLK_null" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "CLK_REGS" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "CLK_RESETTIMER" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "CLK_TIMERNUM" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "DDR" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "GBL_L2MODE" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "GBL_TRCMASKVALUE" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "HWI_CFGDISPATCHED" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "hwi0" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi1" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi10" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi11" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi12" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi13" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi14" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi15" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi2" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi3" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi4" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi5" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi6" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi7" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi8" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "hwi9" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "IDL_busyObj" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IDL_busyObj$avgfmt" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IDL_busyObj$maxfmt" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IDL_busyObj$stsobj" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IDL_busyObj$sumfmt" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IDL_cpuLoad" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IDL_cpuLoad$" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IDL_END" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IDL_END$" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "IRAM" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "KNL_swi" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "KNL_swi$sts" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "KNL_swi$sts$avgfmt" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "KNL_swi$sts$maxfmt" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "KNL_swi$sts$stsobj" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "KNL_swi$sts$sumfmt" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "LNK_dataPump" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "LNK_dataPump$" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "LOG_system" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "LOG_system$buf" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "LOG_system$size" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "MSGQ_USEMSGQ" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "MSGQ$" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "POOL_USEPOOL" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "POOL$" redefined: first defined in "./hellobios5cfg.obj"; hellobios5 C/C++ Problem
#10056 symbol "PRD_clock" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_dispatcher" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_dispatcher$" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost$buf" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost$pipe" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost$pipe$aaa" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost$pipe$bbb" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost$pipe$dtab" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost$pipe$rd" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost$pipe$wr" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_fromHost$rtdx" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost$buf" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost$pipe" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost$pipe$aaa" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost$pipe$bbb" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost$pipe$dtab" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost$pipe$rd" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost$pipe$wr" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "RTA_toHost$rtdx" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "SYS$config" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "TSK_idle" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "TSK_idle$stack" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "TSK_idle$stkptr" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "TSK_idle$sts" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "TSK_idle$sts$avgfmt" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "TSK_idle$sts$maxfmt" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "TSK_idle$sts$stsobj" redefined: first defined in hellobios5 C/C++ Problem
#10056 symbol "TSK_idle$sts$sumfmt" redefined: first defined in hellobios5 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 9 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 14 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 22 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 25 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 28 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 31 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 33 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 40 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 42 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 44 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 46 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 49 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 52 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 54 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 61 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 63 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 70 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 72 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 85 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 89 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 90 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 229 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 230 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 231 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 232 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 233 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 253 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 272 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 275 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 277 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 278 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 283 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 286 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 289 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 292 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 293 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 294 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 295 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 296 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 297 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 298 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 302 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 305 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 318 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 322 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 326 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 328 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 404 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 406 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 409 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 412 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 415 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 418 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 422 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 424 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 425 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol hellobios5 line 426 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_CACHE_L1D" hellobios5 line 77 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_CACHE_L1P" hellobios5 line 76 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_CLK_PRD" hellobios5 line 274 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_CLK_REGS" hellobios5 line 276 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_CLK_TDDR" hellobios5 line 279 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_DDR" being hellobios5 line 78 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT10" hellobios5 line 109 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT100" hellobios5 line 199 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT101" hellobios5 line 200 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT102" hellobios5 line 201 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT103" hellobios5 line 202 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT104" hellobios5 line 203 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT105" hellobios5 line 204 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT106" hellobios5 line 205 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT107" hellobios5 line 206 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT108" hellobios5 line 207 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT109" hellobios5 line 208 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT11" hellobios5 line 110 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT110" hellobios5 line 209 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT111" hellobios5 line 210 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT112" hellobios5 line 211 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT113" hellobios5 line 212 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT114" hellobios5 line 213 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT115" hellobios5 line 214 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT116" hellobios5 line 215 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT117" hellobios5 line 216 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT118" hellobios5 line 217 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT119" hellobios5 line 218 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT12" hellobios5 line 111 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT120" hellobios5 line 219 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT121" hellobios5 line 220 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT122" hellobios5 line 221 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT123" hellobios5 line 222 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT124" hellobios5 line 223 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT125" hellobios5 line 224 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT126" hellobios5 line 225 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT127" hellobios5 line 226 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT13" hellobios5 line 112 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT14" hellobios5 line 113 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT15" hellobios5 line 114 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT16" hellobios5 line 115 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT17" hellobios5 line 116 C/C++ Problem
#10190-D ./hellobios5cfg.cmd absolute symbol "_EVENT18" hellobios5 line 117 C/C++ Problem
RE: Project build in CCSv5.1 not successful when using the Platform.tci for creating a DSP/BIOS 5.x Configuration File - Added by Gregory Gluszek almost 13 years ago
Hi Christian,
Mike is right, we need more details, but here is my guess at what could perhaps solve your problem (seeing as I've had similar issues in the past):
What is the path you are specifying for "TConf Script Compiler->General Options->Configuration import path" and what is the path to where the MDK Platform.tci file is located?
The "TConf Script Compiler->General Options->Configuration import path" path specification should be something like "${MDK}\sw\DSP\templates" (Where you have an environment variable MDK, which is set to the location of where you installed the MDK) if the Platform.tci is located at "${MDK}\sw\DSP\templates\criticallink\platforms\MityDSP-L138\Platform.tci". The problem may be that you specified this path too far (i.e. "${MDK}\sw\DSP\templates\criticallink\platforms\MityDSP-L138"). I've encountered issues in the past where if you get too specific in this path Code Composer will not be able to find the tci file.
Let us know if this helps any.
\Greg
I forgot to delete the original created *.tcf-file. Now it is almost working - Only one new error appeared:
#5 could not open source file "clkcfg.h" clk.c /hellobios5 line 19 C/C++ Problem
The curious thing for me is, why can the file not be found. with the original *.tcf file it's never a problem.
I took a look in the working tcf-file a couldn't find out reference to path...
I also don't know, where the header-files for the exampleprojects are stored.
to give you more details about my project, I created the following example project:
DSP/BIOS v5.xx Examples/evmOMAPL138 Examples/clk example
can you help me to understand what the *.tcf-file has to do with include pathes?
OK, i found the file i need and now it's working.
thanks
Christian
    (1-5/5)
