Redmine Upgrade 20170106
Reloading the page (shift F5) or clicking a link will ask you to login in the first time. Otherwise you shouldn't have to do anything else.
Please create an issue in the this redmine and assign to Jonathan Cormier if you find any issues or have any questions.
NOTE: If you see any garbled elements, this is caused by the browser caching old items. Pressing shift F5 should reload these elements.
Notable differences:
  • "Update" issue button has been renamed to "Edit". It does the same thing as before...
  • The site is now mobile friendly.
  • File uploads happen immediately so images will show up in the preview
  • Files can be dragged into the window to add them to upload
  • The tags plugin was added which can be added to issues.
  • The checklist plugin was added so a checklist can be added to the description of issues.
  • New and improved edit toolbar. "<>" button will enter code highlighting section. The image button will list images that have been attached and auto enter in the required code to show the image in the post. Also supports the thumbnail syntax.
