SOM Temperature Sensor¶
The Agilex 5 includes voltage sensors and at least one accurate temperature sensor that can be accessed using software messages to the SDM. There is a functioning linux driver for accessing this data as part of the hwmon (hardware monitor) driver / API framework.
The easiest way to get a dump of the sensor temperature is to run the "sensors" command from the linux command line:
root@mitysbc-agilex5:~# sensors
ltc2945-i2c-1-6f
Adapter: 10da1000.i3c
in1: 12.00 V (min = +0.00 V, max = +102.38 V)
(lowest = +12.00 V, highest = +12.03 V)
in2: 998.00 mV (min = +0.00 V, max = +2.05 V)
(lowest = +1.00 V, highest = +1.00 V)
power1: 6.76 W (lowest = 5.44 W, highest = 7.51 W)
(max = 524.29 W, min = 0.00 W)
curr1: 564.00 mA (min = +0.00 A, max = +5.12 A)
(lowest = +0.45 A, highest = +0.63 A)
soc64hwmon-isa-0000
Adapter: ISA adapter
0.8V VCC: 744.00 mV
1.8V VCCIO_SDM: 1.82 V
1.8V VCCPT: 1.82 V
1.2V VCCCRCORE: 1.23 V
0.9V VCCH: 945.00 mV
0.8V VCCL: 739.00 mV
Main Die SDM: +43.9 C
Main Die corner bottom left max: +91.6 C
Main Die corner bottom right max: +91.2 C
Main Die corner top right max: +91.9 C
This will also display other hwmon driver data. On the MitySOM-A5E devkit, the SOM current and voltage sensor on the carrier card is also monitored and will be included in the results from the sensors command above.
