Building the FPGA project and Bootloader with Quartus Pro 24.1
Introduction
The reference project for the MitySOM-A5E and DevKit requires the Quartus Pro 24.1 tools installed and in your path.
For compiling the bootloader, it is required to have the GCC-ARM-11.2 Toolchain installed as well. Instructions for installing and sourcing are below:
wget https://developer.arm.com/-/media/Files/downloads/gnu/11.2-2022.02/binrel/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu.tar.xz
tar xf gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu.tar.xz
rm -f gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu.tar.xz
export PATH=`pwd`/gcc-arm-11.2-2022.02-x86_64-aarch64-none-linux-gnu/bin:$PATH
export ARCH=arm64
export CROSS_COMPILE=aarch64-none-linux-gnu-
Description Repository Branch
Quartus Example Projects git://support.criticallink.com/home/git/mitysom-a5e-ref.git pro_24.1_stable
Quick steps to build
Clone the repository
git clone -b pro_24.1_stable git://support.criticallink.com/home/git/mitysom-a5e-ref.git
Navigate into the root of the Quartus project
cd mitysom-a5e-ref/base_project
Generate the project
The project is set up to be customizable from TCL. To generate the default configuration run the following:
make generate_from_tcl
Build the FPGA project and Bootloader
make jic
This will result in output_files/base_project.hps.jic. The default configuration for the project is for an HPS FIRST style configuration. The base_project.hps.jic file contains the SDM and SPL initial boot software and a partial bitstream to support configuring the HPS EMIF and HPS IO pins. The full FPGA bitstream is found in the output_files/base_project.core.rbf file, which can be loaded off of other boot media (such as the SD-Card on the Dev Kit board) by the HPS during uBoot or by the Linux Kernel.
The JIC file contains the FPGA design and the preloader which is programming into the QSPI NOR. You must update the QSPI NOR / JIC file anytime changes are made to the HPS block in your platform designer is altered.
Program the QSPI NOR with the FPGA design / Preloader
quartus_pgm -m jtag -o "ip;output_files/base_project.hps.jic@2"
Note, the above command is valid if the system is powered and the SDM has loaded a valid configuration bitstream already. The SDM inserts a second JTAG device (the ARM complex) before the FPGA bitstream. If the SOM has not been programmed or has not loaded a valid bitstream, change the above command to:
quartus_pgm -m jtag -o "ip;output_files/base_project.hps.jic@1"
Bootloader
Bootloader Environment
make uboot_script
The compiled output script will be in software/boot.scr
