Using Debian Community Filesystem¶
Guide to convert existing debian sd card to boot on MTK¶
This guide was done using the following image:
https://debian.beagleboard.org/images/bone-debian-8.6-lxqt-4gb-armhf-2016-11-06-4gb.img.xz
This image used kernel tag 4.4.30-ti-rt-r64 and so attached device tree was built for this kernel. It will likely only need minor modifications to work with similar 4.4 kernels.
- Update u-boot
- Build CL u-boot with mityarm335x_maker defconfig. https://support.criticallink.com/redmine/projects/armc8-platforms/wiki/Das_U-Boot_Port#Building-u-Boot
MLO
u-boot.imgU-Boot 2013.10-00069-gf9dd46dead39
- The newer debian images have u-boot installed directly in block device, not in seperate boot partition. So we need to use dd to update it.
sudo dd if=MLO of=/dev/sdi count=1 seek=1 conv=notrunc bs=128k sudo dd if=u-boot.img of=/dev/sdi count=2 seek=1 conv=notrunc bs=384k
- The older debian images with the seperate boot partition should be easier to update by replacing the MLO/u-boot.img file in the boot partition.
- Modify /boot/uEnv.txt file
- Specify the maker board dtb file
dtb=am335x-mitysom-maker.dtb
- Alternative: The bonegreen dtb can be used to get a booting device, but ethernet and cape detection won't work. Likely other things as well.
dtb=am335x-bonegreen.dtb
- Add rootfs type as this variable is missing in our u-boot
mmcrootfstype=ext4 rootwait
- Copy dtb file to sd card
/boot/dtbs/4.4.30-ti-r64/ - Boot device
- Optional: To shut down lightdm gui and free up memory.
root@beaglebone:~# systemctl stop lightdm.service
- Flash board eeprom to get cape manager to work
root@beaglebone:~# dd if=/opt/scripts/device/bone/bbb-eeprom.dump of=/sys/bus/i2c/devices/0-0050/eeprom root@beaglebone:~# hexdump -e '8/1 "%c"' /sys/bus/i2c/devices/0-0050/eeprom �U3�A335BNLT������������* �U3�A335BNLT������������* �U3�A335BNLT������������* �U3�A335BNLT������������* �U3�A335BNLT������������* �U3�A335BNLT������������* �U3�A335BNLT������������* �U3�A335BNLT������������* root@beaglebone:~#
- Reboot
Using a BB-BONE-LCD7-01-00A3.dts compatible cape¶
- Copy dtb overlay file to sd card
Created a "-overlay" device tree which disables spi, hdmi, and audio as they conflict with the LCD cape overlay. This was based off the differences betweenam335x-boneblack.dtsandam335x-boneblack-overlay.dts.
am335x-mitysom-maker-overlay.dts
am335x-mitysom-maker-overlay.dtb - Update /boot/uEnv.txt to use overlay dtb
dtb=am335x-mitysom-maker-overlay.dtb
- Boot
- Verify cape manager found LCD
root@beaglebone:~# dmesg | grep bone_capemgr [ 3.730507] bone_capemgr bone_capemgr: Baseboard: 'A335BNLT,\xffffffff\xffffffff\xffffffff\xffffffff,\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff\xffffffff' [ 3.737956] bone_capemgr bone_capemgr: compatible-baseboard=ti,beaglebone-black - #slots=4 [ 3.752557] bone_capemgr bone_capemgr: slot #0: '4D 7.0 LCD CAPE- 4DCAPE-70T ,00A3,4D SYSTEMS ,BB-BONE-LCD7-01' [ 3.802226] bone_capemgr bone_capemgr: slot #1: No cape found [ 3.846228] bone_capemgr bone_capemgr: slot #2: No cape found [ 3.890227] bone_capemgr bone_capemgr: slot #3: No cape found [ 3.896370] bone_capemgr bone_capemgr: initialized OK. [ 3.939085] bone_capemgr bone_capemgr: slot #0: dtbo 'BB-BONE-LCD7-01-00A3.dtbo' loaded; overlay id #0
