THIS IS A WORK IN PROGRESS
This wiki page provides some basic information about the thermal performance of the MitySBC-A5 (revision 1, with engineering silicon). It will capture some basic scenarios and document various power draw and thermal measurements made in the test.
Summary
Scen Heatsink Ext Airlow Amb. Temp A5 Temp A5 Rise Core Cur (1) Input Volt Input Cur Input Pow Notes
2 None N 24 C 12 v
2 None Y 24 C
2 Sink W/Fan Off N 25 C 12 V
3 Sink W/Fan Off N 24 C 44.25 C 20.25 C 12 V 0.97 A 11.64 W FAN was disabled.
3 Sink W/Fan On N 24 C 29.50 C 5.5 C 12 V 0.99 A 11.88 W 45% Duty on FAN PWM
Additional Notes
Thermal options
No Heatsink, Passive Airflow
No Heatsink, Forced Airflow
Passive heatsink, Passive Airflow
Passive heatsink, Forced Airflow
Active heatsink with integrated fan
Load Scenarios
Scenario 1: Booted to Uboot
Scenario 2: Boot to linux
In this scenario, the base_project is loaded into the FPGA bitstream and the processor allowed to boot to linux and essentially run IDLE while connected to the network. The board was allowed to run for at least 20 minutes before checking the temperature.
Scenario 3: Camera ISP Pipeline Demo
In this scenario, the Altera camera Image Signal Processing demo was run. This demo interfaces with a Raspberry PI HQ (12 MP, 12 bit) on Camera Port 0 and displays the processed output on a 30 Hz 4K DisplayPort output. It exercises some amount of the FPGA Programmable Logic core fabric with the ISP as listed in the fitter port shown below:
Camera ISP Demo Resources
