Building the FPGA project and Bootloader with Quartus Pro 24.2
Introduction
The reference project for the MitySBC-Agilex5 requires the Quartus Pro 24.2 tools installed and in your path.
Description Repository Branch
Quartus Example Projects git://support.criticallink.com/home/git/mitysbc-a5-ref.git pro_24.2_stable
Quick steps to build
Clone the repository
git clone -b pro_24.2_stable git://support.criticallink.com/home/git/mitysbc-a5-ref.git
Navigate into the folder for the reference Quartus project desired to build (E.g. mitysbc-a5e-ref-base)
cd mitysbc-a5e-ref-base
Build the FPGA project and Bootloader
make jic
Program the QSPI NOR with the preloader
Bootloader
Bootloader Environment
make uboot_script
The compiled output script will be in software/boot.scr, this belongs in the FAT partition
