Remote SignalTap
The SLD Hub Controller System Qsys block allows for using SignalTap over TCP/IP, which means a USB blaster is not required. In order to do so you will need the following:
  • SLD Hub Controller System added to your Qsys system
  • SLD Hub driver built as a module for your kernel
  • Add SLD Hub to device tree
  • mmlink application to run in linux on the HPS
  • mmlink_setup.tcl to be run from System Console
Adding SLD Hub to Qsys
Adding SLD kernel support
Adding SLD Hub to devicetree
Running SLD Hub and mmlink on the HPS
Setting up the Host PC to connect
