Building U-Boot 18.1¶
- Building U-Boot 18.1
This guide covers the creation of the Critical Link provided preloader and U-Boot images. Because of the sensitivity of the preloader to the HPS peripheral pin multiplexing and boot options, you must follow the basic flow for generating the auto-generated files used by both the preloader and the U-Boot applications prior to being able to build a working copy of either one. The auto-generated files are not included in the Git repository, so you won't be able to build a preloader or a U-Boot image unless you follow these steps.
Note: The file names and some commands are designed specifically for use with the sample FPGA projects provided by Critical Link.
Building the preloader and U-Boot¶
- Launch the Intel Embedded Command Shell.
Linux/opt/intelFPGA/18.1/embedded/embedded_command_shell.sh
WindowsPress start button and enter SoC EDS 18.1 Command Shell
- Launch the BSP Editor application.
bsp-editor &
- Select File->New HPS BSP....
- Set the Preloader settings directory to <project>/hps_isw_handoff/{qsys_inst_name}_hps_0.
- Uncheck Use default locations.
- Set the BSP target directory to <project>/software/preloader. Note: The BSP Settings file name will update automatically.
- Click OK.
- In the BSP Editor, change the name of the PRELOADER_TGZ file for U-Boot to just uboot-socfpga.tar.gz (remove the path). This will tell the BSP Editor to use a local copy of the tarball that we will download in subsequent steps.
- Make any additional changes as needed. If you are building a preloader for a 5CSx module with ECC then in the BSP Editor, click Advanced and check the checkbox for SDRAM_SCRUBBING.
- Click Generate.
- Change to <project>/software/preloader.
- Modify <project>/software/preloader/Makefile to use the MitySOM-5CSx board configuration instead of the stock Altera DevKit configuration.
sed -i 's/socfpga_\$(DEVICE_FAMILY)/mitysom-5csx/' Makefile sed -i 's/altera\/socfpga/cl\/mitysom-5csx/' Makefile
Windows- If you are compiling in Cygwin, run the following command to pick up needed compatibility patches for MinGW during the build process. This command assumes the SoC EDS is installed to C:/intelFPGA/18.1.
cp /cygdrive/c/intelFPGA/18.1/embedded/host_tools/altera/preloader/uboot-socfpga.patch/cygwin/* .
- Fix a permission issue with the generated code.
sed -i '/update-src:/a\\t@$(CHMOD) -R 755 $(PRELOADER_SRC_DIR)' Makefile sed -i '/@$(CP) -v $< $@/a\\t@$(CHMOD) -R 755 $(PRELOADER_SRC_DIR)' Makefile
- Download a tarball of the U-Boot archive from our server.
git archive --format=tar.gz --prefix=uboot-socfpga/ --remote=git://support.criticallink.com/home/git/u-boot-socfpga.git socfpga_v2013.01.01 > uboot-socfpga.tar.gz
- Build the preloader. The image will be found at <project>/software/preloader/preloader-mkpimage.bin.
/usr/bin/make
- Build U-Boot. The image will be found at <project>/software/preloader/uboot-socfpga/u-boot.img.
/usr/bin/make uboot
Building the U-Boot environment¶
After building U-Boot, the environment must be created. This environment will be stored on the SD card and is used to tell U-Boot where to load the kernel, FPGA image, device tree, and root filesystem from.
- Build the U-Boot environment image. uBootMMCEnv.txt is a human-readable file which has all the U-Boot environment variables required to boot Linux from the SD card. ubootenv.bin is a binary blob that U-Boot will read on startup to populate its environment variables. The image will be found at <project>/software/preloader/ubootenv.bin.
uboot-socfpga/tools/mkenvimage -s 4096 -o ubootenv.bin uBootMMCEnv.txt
