Base Development Board FPGA Project
This project is a base project that was made to test some of the interfaces of the MitySOM 5CSX-H6-42A-RC (Production silicon), which device type 5CSXFC6C6U23C7. Its main features are using the Full HSMC connector as single ended I/O, connecting the FPGA DDR to the HPS memory map, and performing a memory test of the HPS DDR from the FPGA.
NOTE: This project could also be used for the MitySOM 5CSX-H6-42A-RC-X with the following changes:
  • Removing the FPGA DDR controller and Clock Crossing bridge, which also requires removal of the FPGA DDR signals.
  • For 5CSX-H6-42A-RC-X, the device type is 5CSXFC6C6U23C8ES.
Updates
5/2/2014
  • Initial Release
Design Specification
The following design was created using Quartus II version 13.1.4 using the following IP blocks:
High Level System Overview
Features
This project contains the following features:
  • Full HSMC connector setup for single ended I/O
  • Access to FPGA DDR from HPS memory map
  • HPS DDR test from FPGA fabric
Downloads
Current: mitysom_5csx_dev_board_v1_0_050214.zip
