GenTL Software Package Release Notes¶
This page covers release notes for the GenTL Viewer and GenTL provider libraries.
Install Package 2.9.1 (2023-12-20)¶
GenTL provider changes¶
- Fixed bug in GenTL DLL related to GigE Protocol Port Access in multi-threaded environment.
GenTL Viewer Application changes¶
- None
Install Package 2.9.0 (2023-10-06)¶
- Add simulation support for 10 Bit Monochrome pixel data
- Added support for fetching GigE Timestamps and scaling based on GIGE Frequency tick counter
- Updated logic for computing framerate when using GigE with valid timestamps.
- Added support for cameras presenting multiple ROIS per GenICam SFNC configuration.
- Added support for Mono10p pixel format
- Added additional commands for scripting engine
- Added ROI presets feature
- Misc GUI related bug fixes.
Install Package 2.8.0 (2023-07-11)¶
- Fix libusb transfers closing and cleanup. Improves application shutdown and removes a crash that occurred over 10% of the time.
- None
Install Package 2.7.3 (2022-11-18)¶
- None
- Added SSL dll files to fix "Check for updates" help menu item being disabled.
Install Package 2.7.2 (2022-11-14)¶
- Add support for BUFFER_INFO_CONTAINS_CHUNKDATA: Return false to indicate we aren't sending chunk data
- None
Install Package 2.7.1 (2022-11-13)¶
- Corrected XML in GenTL.dll local (vs. device) representation
- supports python/harvesters as of build date
- Present GenICam Enumerations in same order as defined in reference XML
- Added compile time option to enable/disable updater
- Misc cleanup of tab control on video widget.
Install Package 2.7.0 (2022-07-19)¶
- Add support for BUFFER_INFO_TLTYPE
- tcBuffer::GetInfo: Handle case where consumer passes null pBuffer to get size of buffer to allocate
- GIGE: Append camera IP Address to DEVICE_INFO_DISPLAYNAME
- GIGE: Release CCP register in port destructor
- GIGE: Set recv buffer size to 256k for stream socket
- GIGE: Don't exit heartbeat thread on error
- U3V: No longer delete list of devices when interface is closed so we can better set &changed when device list is fetched
- U3V: Add reference counting to open/close interface calls so USB interface isn't closed until all open calls have been closed
- Fix mono dng images so they pass dng_validate
- settings: Fix GenTL tab getting marked dirty on load
- open dialog: Properly refresh device list when cameras are removed
- open dialog: Fix invalid ID error for U3V cameras
- open dialog: Show DEVICE_INFO_DISPLAYNAME as tooltip if available
- mainwindow: Show DEVICE_INFO_DISPLAYNAME in title if available
- about: Show which GenTL DLL/CTI path
Install Package 2.6.7 (2022-06-01)¶
Known issue: Breaks U3V connections, installer has been removed until its fixed
- Make Buffer Queues Thread Safe
- Improve device polling
- Support Retrieving Interface Displayname and Type
- GIGE: Add code block to disable polling on network interfaces not supporting GigE
- GIGE: Keep discovery socket resources and Device List after Close()
- mainwindow: Add indicator for camera errors
- aqcWorker: Allow line arrays buffer height to be greater than sensor size
- Cap sx/sy scaling factor at 8 (somewhat arbitrary) to prevent scaling line images to ridiculous sizes
- Add more descriptive error message when XML cannot be parsed
- Add support for QImage::Format_RGB32
- GenTL Settings Dialog: Add Interface Enables / Timeouts Config
- Rework scanning logic for refreshing available interface / devices.
- Increase the poll rate a bit.
Install Package 2.6.6 (2022-05-12)¶
- GigE: Back off the number of working buffers in the GEV Datastream logic
- Installer: Opens firewall for GigE cameras
Install Package 2.6.5 (2022-04-27)¶
- GigE: Implement the GCGetPortInfo for the GEV interface port object.
- None
Install Package 2.6.4 (2022-04-20)¶
- GigE: Update GigE Data Stream protocol to correct bug in packet resend request logic.
- GigE: Corrected bug in decoding of 16 bit vs 64 bit block IDs.
- GigE: Add packet size discover capability (attempts 9000, 4500, 4000, 3800, 1500, 1400, and 1024 packet sizes).
- GigE: General Datastream throughput improvements
- GigE: Dump packets received that aren't from the connected camera IP address.
- Honor the GenTL Producer Datastream STREAM_INFO_BUF_ANNOUNCE_MIN parameter, if provided.
Install Package 2.6.3 (2022-04-07)¶
- None
- Fix issue with Bayer packed formats where they all were being debayered as RG
Install Package 2.6.2 (2022-03-25)¶
- Fix Bug in GigE discovery logic that might cause an application crash.
- None
Install Package 2.6.1 (2022-03-21)¶
- None
- Fix xml cache dir on first install (Fixes View XML button greyed out)
Install Package 2.6.0 (2022-03-21)¶
- Add support for GigE ethernet cameras
- When looking for cameras, the local network will be scanned with broadcast packets
- Honor polling timeout for discovering cameras
- Support Calling IFOpenDevice immediately after calling TLOpenInterface
- Fixup broken iteration in UpdateDeviceList
- U3V: Limit readback request sizes to honor Max Ack Transfer Length
- U3V: Limit command write sizes to honor Max Cmd Transfer Length
- U3V: Ensure we limit usb transfer size to within the max Windows usb transfer size
- U3V: Fix txbuf buffer size allocation
- U3V: Bug: Increment address when breaking write into multiple usb transfers
- DeviceDialog: Only search for cameras when Open Device Dialog is visible
- Try fetching GenICAM payload value if GenTL cannot provide it
- DeviceDialog: Improve GUI lag when Open Device Dialog is visible
- DeviceDialog: Disallow selecting interfaces "categories" in the device dialog
Install Package 2.5.1 (2022-02-17)¶
- None
- recorder: Fix issue where "Save one frame" was defaulting to Program Files directory
- recorder: Fix issue where "Save one frame" was updating the file prefix for the regular recorder
- Ensure GenICam based widgets are initialized in the correct order
Install Package 2.5.0 (2022-01-17)¶
- None
- plotter: Implement StdDev By Row/Column
- plotter: Remove row/column control for Mean and StdDev ImageStats
- plotter: Update plot stats when enabled or source is changed
- plotter: Use full name for plot types that don't have an index
- plotter: Trigger plot refresh when new temp data is added
Install Package 2.4.5 (2021-12-08)¶
- simcamera: Improved fps accuracy. Uses Windows timeBeginPeriod to set scheduler time to 1ms while simcamera is acquiring
- simcamera: Allow changing fps during acquisition
- simcamera: Increase frame gen performance
- BAE: Add Core module support
- BAE: Improve performance for ISelector nodes
- Handle some GenApi exceptions causing GUI crash
Install Package 2.4.4 (2021-09-29)¶
- u3v: Populate BUFFER_INFO_SIZE_FILLED for each buffer so we can determine how many bytes were actually written to the buffer
- Add Bayer 10/14/16 pixel formats
- BAE: Update ROI presets to 1440x1100
Install Package 2.4.2 (2021-08-09)¶
- None
- BAE: Add recommended ROI presets
Install Package 2.4.0 (2021-08-04)¶
- Various debug print statement changes
- Changes to support new cameras
- simcamera: Improve debug log ring buffer
- Add Dark theme, auto-enabled if Windows 10 "AppsUseLightTheme = 0" is set
- Dark mode setting added to explicitly set light/dark theme
- recorder: Add record mode options to the recorder. Allows syncing record start/stop with camera acquisition
- recorder: Minimize recorder controls when the camera is closed
- recorder: Add frame and pixelformat info to saved filenames. A new setting was added to disable this feature. Defaults to add extra info.
- recorder: Allow saving raw camera data to raw file formats. A new setting to control if raw data or image data (as shown in UI) is saved. Defaults to using raw camera data, Breaking Change
Install Package 2.3.0 (2021-06-21)¶
- simcamera: Add support for mono14/12/10 pixel formats
- simcamera: Reduce code duplication in noise text pattern
- camera settings: Ensure IIntegers, IFloats, IEnumerations are read-only when GenICam says so
- Add support for pixel formats mono14/12/10
- Prevent 0ms frame timeouts to avoid 100% cpu usage when at high framerate
- AqcWorker: Check for DSStartAcquisition errors and stop frame acq on errors
- recorder: Set recorder controls to always on top
- mainwindow: Check plugin for toolbarActions
- mainwindow: Show controls if they are minimized
- recorder: Add record button to toolbar
- recorder: Set recorder controls to always on top (window can still be minimized or closed)
Install Package 2.2.0 (2021-05-04)¶
- None
- command console: Add minimize/maximize to console window
- video widget: Fix off by one error with pixel value picker
- ROI: ROI rect selector stops acquisition before changing ROI
- recorder: User can limit the number of frames recorded
- recorder: Captured frames will start the count at 1 and no longer use frame id
- recorder: Captured frames will by default be put in a timestamped subdirectory (configurable in settings)
- recorder: FLF image format added
- recorder: Populate recorder control file formats
- recorder: Remove frame number from camera_regs.ini
- recorder: Stop acquiring before dumping registers
- recorder: Setup recorder control so it auto sizes itself when shown
- geni command: Add additional register save, progress checkpoints
- geni command: Make progress window modal to block user input
- geni command: Allow canceling register save
- Camera Settings: Support enumerating ISelector nodes in tree (can be disabled in settings)
- mainwindow: Ensure GenICam menu options are disabled when no camera is loaded
- mainwindows: Clear fps when camera is closed
- mainwidget: Show videowidget cursor info in status bar
Install Package 2.1.1 (2021-03-03)¶
- None
- BAE: Rework look
- BAE: Update Gaussian controls
- BAE: Add controls for sensor binning and CFPN
- Add REGWAIT command
- mainwindow: Show error if XML load from camera fails
Install Package 2.1.0 (2021-02-22)¶
- Sim Camera updates
- Add spinner when opening/closing camera
- settings: Autodetecting gentl and plugins paths
- Introduce Sensor Register Editing Tool
- Introduce bae plugin
- Introduce Simple scaling control, like MityViewer, to globally enhance contrast
- Push camera debug buffer onto the standard Log window periodically
- Add option to recorder to save cam registers when recording stops
- settings: On start, load default_gentle.ini if settings are empty
- plotter: Add min/max to tools tab
- plotter: Support plotting average across rows or average across columns
- Add Save/Load Camera Registers action to GenICam menu
- Show <Representation> = HexNumber as base 16
- mainwindow: Ensure window title is consistently set
- mainwindow: Fix case where camera doesn't load but we open video window anyways
Install Package 2.0.0 (2020-10-27)¶
- Update to GenICam API 3.2.0
- Include sim_camera.xml in install directory
- Update to build using VS2019
- Update to opencv 4.5.0
- Update libusb
- Add IR plugin support for Canon 35MMFHDXS
Install Package 1.8.1 (2020-07-29)¶
- None
- Introduce basic plugin for sequenced snapshots
- Add option to restart the application when plugins are changed
- Add option to restart the application from menu
- Fix videosettings ComboBox not updating properly
- Add 35MMFHDXS to compatible model list for IR plugin
Install Package 1.7.0 (2020-05-29)¶
- None
- Clamp IFloat to fix issue with double spinboxes min/max rounding
- CMV50K/CSG14K: Add support for CSG14K in plugin. Add sensor details...
- videosettings: Setup ROI presets using CSG14K and CMV50k sensor details
- camerainterface: Clear TLParamsLocked and mpCurrentFrame after aquiring event becomes false
- camerainterface: Ensure we set TLParamsLocked after various error cases, and...
- videosettings: Update play/pause and camera aquiring handling
- Cleanup various unused methods and variables
- Introduce simple voltage/temperature tabular display widget
- Properly configured Datastream capture for MultiFrame and Single frame data.
Install Package 1.6.0 (2020-04-07)¶
- None
- Add control to sync HDMI Gamma and White Balance terms for cameras supporting HDMI outputs.
- Misc bug-fixes in ROI handling.
- Added support for internal test fixture framework.
Install Package 1.5.0 (2020-02-25)¶
- None
- Fixed default recording dir settings
- Change exposure time to microseconds to match GenTL register.
- recorder: Handle saving images using multiple threads. Allows multiple images to be compressed/encoded simultaneously. Improves framerate when recorder is active.
- Speedup 12bit to 16bit unpack algorithm
- Don't subtract IR if any of the pixels are saturated. Fixes scenes with overexposed spots with an IR camera.
Known issues¶
- Application crashes if camera physically disconnected while application is using it.
- ROI rectangle selection is incorrect if an ROI is already set
Installer Package 1.4.1 (2020-01-28)¶
- None
GenTL Viewer Application change¶
- Fix reported version
Known issues¶
Installer Package 1.4.0 (2020-01-27)¶
- Add grid test pattern to simulated camera
- Add menu entries for user manual and release notes.
- Update application icon
- Add additional display filter to support Mirroring in X/Y on PC side.
- Add (optional) Zoom Navigation overlay to Display View.
- Scroll zoom updates
- Don't support zooming out beyond "full image"
- Allow zooming down to 0.01 size to support larger sensors
- Save / restore click-and-drag zoom operation button when not scroll zooming
- Fix access error when saving plot data with unequal length plot vectors.
- Save State of Zoom Navigation, Pixel Interpolation Mode, and 1:1 checkbox.
- Fix up panning logic and properly display pixel coordinates when zoomed.
- Add ROI image rectangle selection to video settings plugin, so you can drag a rectangle to set ROI
- Add ROI preset combo box
- Disable ROI buttons when camera is acquiring
Known issues¶
Installer Package 1.3.0 (2019-12-04)¶
- Internal updates
- Fix memory leak
- Reset zoom when image size changes
- Updates to installer to provide smoother update installation
- Update to IR plugin to subtract IR value from RGB pixels
Known issues¶
Installer Package 1.2.0 (2019-10-14)¶
- Simulated camera updates for testing
- Improve error handling in XML parser
- Corrected PNG data format for high bit depth images.
- Add support for monochrome images to DNG export.
- Add support for Canon IR pixel format
- Add White Balance control to UI
- Minor user interface fixes
Known issues¶
Installer Package 1.1.2 (2019-08-05)¶
- Advanced libusb to include changes from 1.0.22 release. Needed to support very large image transfer.
- Updated histogram to support plotting 2^N bins for a given color bit-depth
- Updated histogram to center pins properly when plotting
- Fixed misc issues around exception handling for exceptions thrown by GenICAM
Installer Package 1.1.1 (2019-01-11)¶
- Fix misc bugs encountered with data streaming.
- Add XML / Port accessors for interface and system modules in the GenTL layer.
- Simulated camera support added with bug fixes.
- Handle proper model numbering for plugin matching with CMV and CSG based cameras.
Installer Package 1.1.0 (2018-11-12)¶
- Several fixes made to support utilizing python harvester bindings.
- Fixed Error in Revoke Buffer method when buffer was allocated by external application (vs. with the Library).
- Return GC_ERR_NOT_IMPLEMENTED for GetPortURL related methods for non-Port Handles vs. unexpected behavior.
- Fixed some system handle GetInfo() routines returning strings to include null termination character in returned string and size calculation.
- Added support for digital raw negative file format for saving images.
Installer Package 1.0.0¶
Installer Package 0.9.0¶
Installer Package 0.8.0¶
