Root Filesystem (2018 March MDK Release)¶
SD Card based Root Filesystem¶
Installing the filesystem¶
The MDK comes packaged with a prebuilt root filesystem. This can be found in the MDK's install directory under deploy.
First, backup the filesystem currently on the SD card (you will need to modify the paths based on your specific Linux distribution):
sudo cd /path/to/media/rootfs/ sudo tar czvf ~/rootfs-backup.tar.gz .
Then, you can install the new root filesystem with
rm -rf /path/to/media/rootfs/* tar xvf /opt/criticallink/mitysom-335x_2018-03-16/deploy/mitysom-335x-devkit-rootfs.tar.bz2 -C /path/to/media/rootfs/ sync
NOTE: It's recommended that you flush any buffered data to the root filesystem media with sync to avoid corruption. This command will not print any status output and can take a long time to run depending on the write speed of the media.
Please note that when you update the root filesystem to the latest MDK, you will also want to replace your kernel image with the latest MDK's kernel image.
Installing U-Boot and Linux¶
cp <MDK path>/deploy/<SOM NAND size>/MLO /path/to/media/boot/ cp <MDK path>/deploy/<SOM NAND size>/u-boot.img /path/to/media/boot/ cp <MDK path>/deploy/zImage-zImage_devkit.bin /path/to/media/boot/zImage cp <MDK path>/deploy/zImage--4.4.32-devkit+<git hash>-r1-am335x-mitysom-<SOM configuration>-<date>.dtb /path/to/media/boot/am335x-mitysom.dtb sync
When installing the device tree, the device tree must be selected based on the NAND (256M/512M/1G) and NOR (with or without) configuration of the SOM.
For example:- 256MB NAND with NOR, use
am335x-mitysom-256M-NOR - 512MB without NOR, use
am335x-mitysom-512M
Booting the Root Filesystem¶
U-Boot can boot using the SD card root filesystem with
U-Boot# mmcinfo; setenv fdtaddr 0x88000000; setenv fdt_high 0xFFFFFFFF; setenv kloadaddr 0x80007FC0; U-Boot# fatload mmc 0 $kloadaddr zImage U-Boot# fatload mmc 0 $fdtaddr am335x-mitysom.dtb U-Boot# setenv console "ttyS0,115200n8" U-Boot# run mmc_args U-Boot# bootz $kloadaddr - $fdtaddr
These commands can be saved as the default boot command
U-Boot# setenv console "ttyS0,115200n8" U-Boot# setenv bootcmd "mmcinfo; fatload mmc 0 0x80007FC0 zImage; fatload mmc 0 0x88000000 am335x-mitysom.dtb; run mmc_args; bootz 0x80007FC0 - 0x88000000" U-Boot# saveenv
NAND based Root Filesystem¶
See UBIFS Nand Boot.
Before building the UBIFS image, unpack the prebuilt root filesystem that ships with the MDK. This may be found in the MDK's install directory under deploy.
cd <your working directory> mkdir filesystem tar xf /opt/criticallink/mitysom-335x_2018-03-16/deploy/mitysom-335x-devkit-rootfs.tar.bz2 -C ./filesystem
Network Boot¶
TFTP¶
U-Boot loads the zImage and device-tree over the network using TFTP.
Install the TFTP server
sudo apt-get install tftpd-hpa
Configure the server
Add/Update the following line in /etc/conf.d/tftpd:
TFTPD_DIRECTORY="/srv/tftp"
Create the TFTP folder
mkdir -p /srv/tftp
Reload the TFTP server
sudo service tftpd-hpa restart
Add the kernel image and device tree from the MDK
mkdir /srv/tftp/mitysom/ cp /opt/criticallink/mitysom-335x_2018-03-23/deploy/zImage-zImage_devkit.bin /srv/tftp/mitysom/zImage cp /opt/criticallink/mitysom-335x_2018-03-23/deploy/<device tree>.dtb /srv/tftp/mitysom/am335x-mitysom.dtb
NFS¶
After U-Boot loads the kernel, the kernel may use an NFS drive as it's root filesystem.
Install an NFS server
sudo apt-get install nfs-kernel-server
Make the NFS rootfs folder
mkdir -p /srv/nfs/mitysom
Export the rootfs folder
Add the following entry to /etc/exports:
/srv/nfs/mitysom *(rw,async,nohide,insecure,no_root_squash,no_subtree_check)
Update the NFS server's exports
sudo exportfs -arv
Make the NFS server serve over UDP
Add the following to /etc/nfs.conf
[nfsd] udp=y vers2=y
Restart the NFS server
systemctl restart nfs-server.service
Uncompress the MDK rootfs
tar xf /opt/criticallink/mitysom-335x_2018-03-23/deploy/mitysom-335x-devkit-rootfs.tar.bz2 -C /srv/nfs/mitysom
In order to sucessfully boot, DHCP needs to be disabled in systemd for the network adapter connecting to the NFS server.
mkdir -p /srv/nfs/mitysom/etc/connman vi /srv/nfs/mitysom/etc/connman/main.conf
Then add the following lines to
/srv/nfs/mitysom/etc/connman/main.conf:[General] NetworkInterfaceBlacklist=eth
Booting¶
Configure and boot U-Boot:
U-Boot# set kloadaddr 0x80007FC0 U-Boot# set fdtaddr 0x88000000 U-Boot# set serverip <host machine IP> U-Boot# set rootpath "/srv/nfs/mitysom" U-Boot# set autoload no U-Boot# set bootcmd "dhcp; tftp $kloadaddr /mitysom/zImage; tftp $fdtaddr /mitysom/am335x-mitysom.dtb; run net_args; bootz $kloadaddr - $fdtaddr;" U-Boot# saveenv U-Boot# boot
