PowerVR Graphics
Yocto
MDK Release September 2015 Yocto
- Yocto already provides the PowerVR Graphics in the build so this guide is not required
Recommendation for TI SDK Release
We recommend using Texas Instruments comprehensive guide on it's Graphics SDK.
The web site for the TI Graphics SDK is http://processors.wiki.ti.com/index.php/Graphics_SDK_Quick_installation_and_user_guide
The following sections are used in conjunction with the above guide.
Modifications to Rules.make
This file is located in the root of the Graphic SDK installation path
Graphics_SDK_4_10_00_01
Rules.make -- Top section of file
################# FIELDS MODIFIABLE BY THE USER ###############################
############### All the fields below are MANDATORY ############################
#By default all below variables have been initialized with equivalent AMSDK variables
# Change them to appropriate paths as per your machine/build environment paths.
# Set home area (ex /home/user/)
#HOME=$(SDK_INSTALL_DIR)/graphics
HOME=/home/mitydsp
# Set Toolchain path (ex /home/user/toolchain/arago-2011.09/armv7a)
CSTOOL_DIR=/usr/local/ti-sdk-am335x-evm/linux-devkit/
# Set Tool chain prefix (ex arm-arago-linux-gnueabi- )
CSTOOL_PREFIX=arm-arago-linux-gnueabi-
# Set kernel installation path ( ex /home/user/linux-04.00.01.13 )
KERNEL_INSTALL_DIR=/home/mitydsp/projects/linux-mityarm-335x/
# Set Target filesystem path ( ex /home/user/targetfs )
TARGETFS_INSTALL_DIR=/home/mitydsp/projects/rootfs
# Set installation folder
GRAPHICS_INSTALL_DIR=$(HOME)/Graphics_SDK_4_10_00_01
Basic command to use for our Devkit
  • Previously PM_RUNTIME=1 was not needed, but with the new 3.2 PSP11 update it is required or else the kernel will fail to load the graphics modules. For more information see the link below.
    TI SGX Wiki
Commands Run:
  • export ARCH=arm
  • make BUILD=release OMAPES=8.x PM_RUNTIME=1 all_km
  • make BUILD=release OMAPES=8.x PM_RUNTIME=1 install_km
Modifications to etc/init.d/rc.pvr start script
Modified rc.pvr to only start if 3354/9 module
#@Title         PowerVR SGX DDK for Embedded Linux
#@Copyright     Copyright (c) Imagination Technologies Ltd. All Rights Reserved
#@License       Strictly Confidential.
# Auto-generated for omap_linux from build: sgxddk_1.10@2359475
+cpu_type=$(/usr/bin/mityarm_cputype.sh)
+if [ "$cpu_type" -eq "3352" ]
+then
+        echo "3D acceleration is not available in the am3352 family"
+        exit 1
+fi
