mityarm-linux-stable - Currently 3.12¶
Branched from v3.11.1 - https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tag/?id=v3.11
Currently merged upto v3.12 - https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tag/?id=v3.12
Known issues¶
- No nand support
- No mmc support
- Only boot via initramfs
- No eth support
- Etc.
Build instructions¶
This version requires a newer version of the binutils. Easiest way is to use Linaro toolchain which comes with the latest 335x SDK.
Creating initrd image: https://www.kernel.org/doc/Documentation/initrd.txt
$ $ make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm distclean $ make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm omap2plus_defconfig $ make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm zImage modules $ make CROSS_COMPILE=arm-linux-gnueabihf- ARCH=arm dtbs
Device tree file will be located at arch/arm/boot/dts/mityarm335x-devkit.dtb
u-boot boot cmds:
$ mmc rescan 0 $ fatload mmc 0 80000000 mityarm335x-devkit.dtb $ fatload mmc 0 81000000 zImage $ fatload mmc 0 82000000 ramdisk-pm.gz $ setenv bootargs console=ttyO0,115200n8 mem=256M root=/dev/ram rw initrd=0x82000000,16MB ramdisk_size=65536 earlyprintk=serial $ bootz 81000000 - 80000000
Problems¶
If you see the following error:
arch/arm/boot/dts/omap2.dtsi:11:35: fatal error: dt-bindings/gpio/gpio.h: No such file or directory compilation terminated.
Then do the following to fix it
$ cd arch/arm/boot/dts/include/ $ rm dt-bindings $ ln -s ../../../../../include/dt-bindings .
