MitySOM-335X Architecture¶
- I2C0 [ Edge connector ]
- No pull-up resistors on module
- No pre-defined uses
- I2C1 [ Edge connector ]
- Pull-up reistors installed on module
- Factory configuration EEPROM (address 1010XXXb - hex 0x50 to 0x57)
- PMIC SmartReflex interface(address 0101101b - hex 0x12)
- I2C2 [Not available on the edge connector]
The MitySOM-335x module can support up to 2 Serial Peripheral Interface (SPI) ports:
- PMIC Peripheral interface(address 0010010b - hex 0x2D)
- SPI0 [ Edge Connector ]
- SPI1 [ Edge Connector ]
- Modules WITH NOR memory use SPI1 CS0 for the NOR, CS1 is available
- Modules without the NOR memory have both CS0 and CS1 available.
