MitySOM-3359 Alpha Release¶
This page outlines the release requirements for the MitySOM-3359 Alpha Release.
Contents¶
The MitySOM-3359 Alpha release consists of the following hardware items:
- MitySOM-3359 Module
- MitySOM-335x Development Kit Baseboard
- Power Supply
- UART adaptor
- Serial Cable (for console port)
- installed SD-card with boot image
- USB Stick with support software / documentation
Requirements¶
The minimum operational requirements for the module hardware include:
- System Powers Up to u-Boot
- Image should be loaded from installed MMC card
- System PLL's should be configured for TBD MHz operation
- DDR2 should be properly configured
- Factory I2C prom should be read for serial number and MAC address
- MMC should be configured
- Any PMIC configuration to support full speed operation should be performed
- u-Boot ethernet access functional
- u-Boot console port function @ 115200 BAUD
The minimum requirements for the installed USB stick include:
- A virtualbox appliance image should be provided including
- a working ubuntu installation
- all native linux tools for building the kernel and application
- a copy of the u-Boot software used to create the image
- Schematics and Specifications for the Development Kit
- Specifications for the SOM
- PCB designers guide
For this release, a functioning linux kernel on the target (and sources on the virtualbox image) are not required, but are a goal.
