Das U-Boot Port - Compile and Install
https://support.criticallink.com/gitweb/?p=u-boot-mityarm-335x.git;a=summary
Please familiarize yourself with the TI port of u-boot described here as the Critical Link MitySOM-335X port is based on the TI port, and many of the AM335X processor specifics are detailed on the TI wiki.
Branch Description
u-boot-2019.01: Latest U-Boot supported by Critical Link for the am335x.
Checkout U-Boot
Download your own copy of U-Boot (please replace the X's with your desired branch):
git clone git://support.criticallink.com/home/git/u-boot-mityarm-335x.git
cd u-boot-mityarm-335x
git checkout -b  u-boot-XXXX.XX origin/u-boot-XXXX.XX
These commands will download the repository and check out the specified branch from the server. If you intend to make changes you will need to be moderately familiar with Git (See the docs).
Setting up the environment
If the MDK is installed to the default directory:
source /opt/criticallink/mitysom-335x_XXXX-XX-XX/environment-setup-cortexa8hf-neon-criticallink-linux-gnueabi
Building U-Boot
The U-Boot build needs to be configured depending on which SOM you're using.
  • mitysom335x_devkit_256MB_defconfig - Config for 256MB NAND SOMs
  • mitysom335x_devkit_512MB_defconfig - Config for 512MB NAND SOMs
  • mitysom335x_devkit_1GB_defconfig - Config for 1GB NAND SOMs
    SOMs with no nand can use any of the above configs
make distclean
make mitysom335x_devkit_<nand size>_defconfig
make
For a faster build, add "-j$(nproc)" to build with multiple threads, $(nproc) will use as many threads as the building machine has cores.
When built successfully, there are several files created in the source directory.
  • spl/u-boot-spl.bin - The second-stage bootloader (a stripped down version of u-boot that fits in SRAM)
  • MLO - spl/u-boot-spl.bin with a GP image header prepended to it
  • u-boot.img - The full-fledged U-Boot image.
NAND
This section outlines the configuration of the NAND device in U-Boot (which corresponds to the NAND MTD parts in the default Critical Link built Linux kernel).
Note: Offset fields must be aligned with 0x800 (2048) bytes. On writing 3000 (0xbb8) bytes, len field can be aligned to 0x1000 ie 4096 bytes.
Offset field should be aligned to page start address, multiple of 2048 bytes.
NAND Layout
See UBIFS Nand Boot
Reflashing U-Boot
If you need to reflash the U-Boot image to your board, you can follow the instructions below. WARNING: failure to perform this step correctly will "brick" your board. The procedure for recovering a bricked module is dependent on the carrier board setup (or you can return it to Critical Link for service).
If you are using the Critical Link dev board, U-Boot and the MLO are stored on the SD card, and can simply be updated on the card. Check the TI AM335x U-Boot User's Guide if you are booting from flash or other external boot devices.
Writing to NAND
See UBIFS Nand Boot for full details on creating a full nand boot scenario on both the 256MB and 512MB Nand parts.
Writing to the SD card
If you are booting from an SD card (as shipped from Critical Link), you can simply replace the MLO and u-boot.img files on the first partition of the SD card. This partition is a FAT partition and can be written to from Linux or Windows (or many others).
