U-boot env userspace tool¶
U-boot provides a userspace tool you can build, to print and update the u-boot environment stored in mtd4
root@mityomapl138:~# cat /proc/mtd mtd0: 08000000 00020000 "rootfs" mtd1: 08000000 00020000 "homefs" mtd2: 00010000 00010000 "ubl" mtd3: 00080000 00010000 "u-boot" mtd4: 00010000 00010000 "u-boot-env" <--------------- mtd5: 00010000 00010000 "periph-config" mtd6: 00050000 00010000 "reserved" mtd7: 00300000 00010000 "kernel" mtd8: 00200000 00010000 "fpga" mtd9: 00200000 00010000 "spare"
Build and install¶
- Follow instructions to build Das_U-Boot_Port
- Run makearm env
- Copy tools/env/fw_printenv to /usr/sbin
- Symlink fw_setenv
ln -sf fw_printenv /usr/sbin/fw_setenv - Copy tools/env/fw_env.config to /etc/fw_env.config
Use tool¶
Usage:
fw_printenv [[ -n name ] | [ name ... ]]
- prints the value of a single environment variable
"name", the ``name=value'' pairs of one or more
environment variables "name", or the whole
environment if no names are specified.
fw_setenv name [ value ... ]
- If a name without any values is given, the variable
with this name is deleted from the environment;
otherwise, all "value" arguments are concatenated,
separated by single blank characters, and the
resulting string is assigned to the environment
variable "name"
root@mityomapl138:~# fw_printenv
bootdelay=3
baudrate=115200
root@mityomapl138:~# fw_setenv test 1
root@mityomapl138:~# fw_printenv test
test=1
Read-only¶
Note if you get a "Can't open /dev/mtd4: Permission denied", the mtd partition may be marked as read-only
- Check board-mityomapl138.c
.mask_flags = MTD_WRITEABLEwill clear the writeable flag - You can also check mtdinfo
# mtdinfo /dev/mtd4 mtd4 Name: u-boot-env Type: nor Eraseblock size: 65536 bytes, 64.0 KiB Amount of eraseblocks: 1 (65536 bytes, 64.0 KiB) Minimum input/output unit size: 1 byte Sub-page size: 1 byte Character device major/minor: 90:8 Bad blocks are allowed: false Device is writable: false <------
To make the partition writable, you can either remove the .mask_flag line from the mtd partition. board-mityomapl138.c
Or a mtd unlock option was added in our 3.2 kernel but needs to be enabled CONFIG_MTD_UNLOCK
This makes the partition writable until relocked.
echo unlock > /sys/devices/platform/spi_davinci.1/spi1.0/mtd/mtd4/unlock fw_setenv test 1 echo lock > /sys/devices/platform/spi_davinci.1/spi1.0/mtd/mtd4/unlock
