The GPIO Core
This is a documentation page for using the Critical Link GPIO core.
  • The FPGA GPIO Core pins start at pin #144 on the Linux side of things.
  • So pin #144 will map to the first gpio in the first gpio core. The gpio core will then be connected to a net name which gets mapped to a fpga pin name in the .ucf file. See $MDK/examples/industrial_io/fpga/vhdl/IndustrialIO_rev_C.ucf for example.
Component Instantiation
There are effectively three scenarios in which the GPIO core can be instantiated:
  1. GPIOs as Inputs
    GPIO_INST : gpio
        generic map
            NUM_BANKS       => 1,
            NUM_IO_PER_BANK => 16
        port map
            clk => ema_clk,
            i_ABus => addr_r,
            i_DBus => edi_r,
            o_DBus => edo5(CORE_GPIO),
            i_wr_en => wr_r,
            i_rd_en => rd_r,
            i_cs => cs5_r(CORE_GPIO),
            o_irq => irq_map(CORE_GPIO_LVL)(CORE_GPIO_VEC),
            i_ilevel => conv_std_logic_vector(CORE_GPIO_LVL, 2),
            i_ivector => conv_std_logic_vector(CORE_GPIO_VEC, 4),
            i_io => i_gpio, -- GPIO read values
            t_io => open, -- Direction of GPIOs
            o_io => open, -- GPIO write values
            i_initdir => x"0000", -- default to all inputs
            i_initoutval => x"0000"
  2. GPIOs as Outputs
    GPIO_INST : gpio
        generic map
            NUM_BANKS       => 1,
        port map
            clk => ema_clk,
            i_ABus => addr_r,
            i_DBus => edi_r,
            i_wr_en => wr_r,
            i_rd_en => rd_r,
            i_io => s_gpio, -- GPIO read values. Loop back output values so they can be read from software.
            t_io => open, -- Do not care about direction of GPIOs
            o_io => s_gpio, -- GPIO write values
            i_initdir => x"FFFF", -- default to all outputs
        -- Set output ports
        o_gpio <= s_gpio;
  3. GPIOs as Bidirectional Inputs and Outputs
    GPIO_INST : gpio
        generic map
            NUM_BANKS       => 1,
        port map
            clk => ema_clk,
            i_ABus => addr_r,
            i_DBus => edi_r,
            i_wr_en => wr_r,
            i_rd_en => rd_r,
            i_io => io_gpio, -- GPIO read values
            t_io => t_gpio, -- Direction of GPIOs
            o_io => o_gpio, -- GPIO write values
    -- Process to drive inout ports when GPIO core is in output mode or set to high Z when GPIO core is in input mode
    GEN_GPIO_IOBS : for i in 0 to 15 generate
    begin
       io_gpio(i) <= o_gpio(i) when t_gpio(i) = '0' else 'Z';
    end generate GEN_GPIO_IOBS;
