Reprogramming the Bootloader¶
Reprogramming a Dead/Bricked Board¶
This procedure will allow you to reprogram the User Boot Loader (UBL) and u-Boot image on a MityDSP-L138/MityARM-1808 module via the serial port AIS bootloader (via UART1, the console port for MityDSP-L138). The AIS bootloader is entered by holding the boot-option button down while resetting (or powering up) a board installed on the Industrial I/O board.
This procedure should only be needed if a user has corrupted the base of the SPI-NOR FLASH containing the factory installed user-boot-loader and boot image.
This procedure should not be used if a user can boot to the U-Boot prompt. If U-Boot still runs on the board and needs to be updated or repaired, the instructions on the Das U-Boot page should be used instead.
This procedure does not restore kernel/FPGA or root filesystem/NAND data.
Requirements:- Industrial I/O board or host board with capability to pull ext-boot pin option low.
- PC running Windows XP/Vista/7/10 with a serial port (Note: Utility can be run from Linux using mono)
Procedure:
- Extract the latest files in this zip file (Dead Board Programming Files) to a directory on your PC.
- The readme.txt file within details the files included and MD5sums for verification
- Alternatively, follow the steps outlined in First Stage User Boot Loader and Second Stage Das U-Boot Port to generate the necessary UBL_SPI_MEM.ais and u-boot.bin files.
- Connect the PC serial port to the console port of the MityDSP-L138 host board.
- Start a command line on the PC with Start-->Run "cmd"
- Change directories to the location of the files extracted from the zip file
- Run the command:
c:\yourlocation> sfh_OMAP-L138 -flash -v -p COMx UBL_SPI_MEM.ais u-boot.bin
In the command, COMx should be replaced with the proper COM port number (e.g., COM1, COM3, etc.) of the serial port attached to the MityDSP-L138 host board.
Linux:mono sfh_OMAP-L138.exe -flash -v -p /dev/ttyUSB0 UBL_SPI_MEM.ais u-boot.bin - While holding the 'boot me' button, apply power or reset the MityDSP-L138 host board. If successful, you should see text on the console similar to:
(AIS Parse): BOOTME received! (AIS Parse): Performing Start-Word Sync... (AIS Parse): Performing Ping Opcode Sync... (AIS Parse): Processing command 0: 0x58535901. (AIS Parse): Performing Opcode Sync... (AIS Parse): Loading section... (AIS Parse): Loaded 8484-Byte section to address 0x80000000. (AIS Parse): Processing command 1: 0x58535901. (AIS Parse): Performing Opcode Sync... (AIS Parse): Loading section... (AIS Parse): Loaded 716-Byte section to address 0x80002124. (AIS Parse): Processing command 2: 0x58535906. (AIS Parse): Performing Opcode Sync... (AIS Parse): Performing jump and close... (AIS Parse): AIS complete. Jump to address 0x80000000. (AIS Parse): Waiting for DONE... (AIS Parse): Boot completed successfully Waiting for SFT on the OMAP-L138... Target: BOOTUBL Target: DONE Flashing UBL UBL_SPI_MEM.ais (8396 bytes) at 0x00000000 Target: INFO: SPI Memory Initialization passed. Target: Flashing UBL... Target: SENDIMG Target: BEGIN 100% [ ████████████████████████████████████████████████████████████ ] Image data transmitted over UART. Target: DONE 100% [ ████████████████████████████████████████████████████████████ ] UBL programming complete Target: Doing block erase.SENDING Target: SENDING Target: SENDING Target: UBL flashed correctly. Target: DONE Flashing application u-boot.bin (254972 bytes) at 0x00010000 Target: SENDIMG Target: BEGIN 100% [ ████████████████████████████████████████████████████████████ ] Image data transmitted over UART. Target: DONE 100% [ ████████████████████████████████████████████████████████████ ] Application programming complete Target: Doing block erase.Doing block erase.Doing block erase.Doing block erase.SENDING Target: SENDING ... Target: SENDING Target: Finished writing to SPI, now verifying. Target: DONE Target: DONE Operation completed successfully.
At this point, the user-boot-loader and the u-Boot image should be reprogrammed into the SPI-NOR flash. You should be able to launch your terminal program and reset the host board and see the u-Boot prompt as expected.
If you get a message:
*** Warning - bad CRC, using default environment
in the u-Boot startup, then the u-Boot environment has been reset. You will need to restore any environment settings you had added to your system, and the save the environment using "saveenv".
Error - Checksum on MityDSP-L138 Config Block Checksum Invalid. You must set the config to FLASH to make permanent
in the u-Boot startup, then the OMAP peripheral configuration block (which selects which emac interface to use, ports to configure, etc.) must be reset and saved. For the industrial I/O board, the default settings should be OK. You can apply the settings be running (and just hitting return for all the prompts):
U-Boot > config set Ethernet Config : 2 [default] UART - 0 Configuration --- Enable UART : 0 [default] UART - 1 Configuration --- Enable UART : 1 [default] Baud : 115200 [default] HW Flow Control : 0 [default] Is Console : 1 [default] UART - 2 Configuration --- Enable UART : 0 [default] SPI - 0 Configuration --- Enable SPI : 0 [default] SPI - 1 Configuration --- Enable SPI : 1 [default] CLK is Output : 1 [default] Chip Select [0] Enable : 01 [default] Chip Select [1] Enable : 00 [default] Chip Select [2] Enable : 00 [default] Chip Select [3] Enable : 00 [default] Chip Select [4] Enable : 00 [default] Chip Select [5] Enable : 00 [default] Chip Select [6] Enable : 00 [default] Chip Select [7] Enable : 00 [default] ENA ENable : 0 [default] CLK Rate : 30000000 [default] LCD Configuration [default] LCD Enable : 0 [default] U-Boot > config save Configuration Saved
Finally, to get the board to boot off of flash:
run flashbootargs
Note: Serial flash programming utilities can be found in the MDK ( see http://support.criticallink.com/redmine/projects/arm9-platforms/files )
To restore the u-Boot default environment, execute the following commands from u-Boot:
sf probe 0 sf erase 0x90000 0x10000
| uBoot Date and Programming Files Download Link |
| Feb 17 2026 - 16:49:00 |
| Jan 05 2024 - 14:10:19 |
| Jan 03 2018 - 11:30:43 |
| Mar 31 2011 - 19:39:18 |
