Hardware Design Guidelines
The table below includes relevant links for host (carrier) board design guide documents for the ARM9 based SoMS.
Module PCB Design Guide Document
MityDSP-L138F Design Guide
MityARM-1808F Design Guide
MityARM-1810F Design Guide
MityDSP-L138 Design Guide
MityARM-1808 Design Guide
MityARM-1810 Design Guide
Other notes
  • Do not plan to use I2C0 for DSP side access. I2C0 is used on-module by the ARM to access factory config data as well as the power management IC, so it is allocated to the ARM core.
