Debian SDK Not booting in am62p (Am62x dev kit)
Added by Rajkumar Dumala 4 months ago
Hello There,
We have a MitySOM-AM62x Development Kit and the AM62P family SoM as well. I flashed the Debian image onto the SD card and tried to boot the board, but it didn't boot, and nothing is printing on the Putty terminal (/tty/USB1 on Linux).
Could you please help me understand why this is happening?
We have previously worked with the TI evaluation board and their Debian SDK for development. Can this be directly ported into Critical Link's development kit?
The reference SD card from Critical Link seems to have a Yocto-based SDK (apt was not available). For our application requirements, we need to install the EtherCAT Igh master and ROS2 Humble (from source) on the Debian SDK. Could you provide the procedure to flash a Debian OS?
Thank you,
Rajkumar.
Replies (28)
RE: Debian SDK Not booting in am62p (Am62x dev kit) - Added by Michael Williamson 4 months ago
Hi Rajkumar,
Did you note the (brief) instructions here:
https://support.criticallink.com/redmine/projects/mitysom_am62x/wiki/Repositories_and_Pre-built_Images#Debian-Image-Not-typically-needed
The reference image from TI will need to be updated to use the CL bootloader (to deal with RAM and console port changes), kernel, and kernel configuration (devicetree) files. Then it will boot up.
If time permits I can try to pull a procedure together. It may be a few days.
With regards,
Mike
RE: Debian SDK Not booting in am62p (Am62x dev kit) - Added by Rajkumar Dumala 4 months ago
Hi Mike,
Thanks for your reply.
I flashed the reference microSD card image (Debian) provided by Critical Link, not the one from TI.
The Image That is available inside the table(By default, this image is for HS-FS SOMs TI Debian Bookworm Processor SDK 10.0 (>700MB, A 16GB OR LARGER SD CARD is required))
Does this image already include the Critical Link bootloader, kernel, and kernel configurations, or do we need to replace them manually?
If we need to make changes, could you please let me know which image I should use as a reference to work with Debian?
Rajkumar.
Hi Mike,
I'll try the image that you sent and will update you on the status.
Thank you.
RE: Debian SDK Not booting in am62p (Am62x dev kit) - Added by Jonathan Cormier 4 months ago
Note replace references of am62x with am62p. So make sure to download the am62p tisdk image and but still start with the am62 debian image.
TI does have a 62p debian sdcard image as well, though in reality they should be mostly identical other than the u-boot and kernel files.
Hi Rajkumar,
The image I provided was for a MitySOM-AM62x, not an MitySOM-AM62P. You'll need to redo what I have listed in the link below with our AM62P reference image. Sorry for the inconvenience.
https://support.criticallink.com/redmine/projects/mitysom_am62x/wiki/Updating_the_TI_EVM_Debian_Image_for_the_MitySOM-AM62x_DevKit
Hi Mike,
Just to clarify, I hadn’t found the link below previously—it looks like it was updated recently:
That said, I had already tried the steps mentioned there before our conversation started. I’d like to clarify two things:
I used the kernel, U-Boot, and device tree files from the SD card that came with the Critical Link kit.
Instead of using the losetup (loopback setup) command, I copied the files directly using the file manager on my Linux system.
For our development, we require a full Debian-based OS because it includes the Linux headers (/usr/src/linux-headers-*) necessary for building the EtherCAT IgH master. As far as I understand, the SDK provided on the Critical Link SD card doesn’t include these headers since it’s based on a BSP/Yocto Linux (please correct me if I’m wrong).
I tried the steps from the link above, but the board did not boot (no working init found). I'm including the recent boot log below for reference.
@@ #1
[    2.010559] Hardware name: Critical Link MitySOM-AM62Px (DT)
[    2.016203] Call trace:
[    2.018641]  dump_backtrace+0x98/0xf8
[    2.022309]  show_stack+0x20/0x38
[    2.025616]  dump_stack_lvl+0x48/0x60
[    2.029274]  dump_stack+0x18/0x28
[    2.032580]  panic+0x338/0x3a8
[    2.035631]  kernel_init+0x1a4/0x1f0
[    2.039197]  ret_from_fork+0x10/0x20
[    2.042767] SMP: stopping secondary CPUs
[    2.046686] Kernel Offset: disabled
[    2.050160] CPU features: 0x0,00000008,00020000,1000420b
[    2.055458] Memory Limit: none
[    2.058505] ---[ end Kernel panic - not syncing: No working init found.  Try        passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for        guidance. ]---
Rajkumar
Hi Rajkumar,
Ok. I rebuilt the image using TI's SDK 10.01 debian trixie am62pxx-evm build (vs. the am62xx build) and only copied the boot files (in the first partition) and added our device tree. I left the kernel and modules the same as the pre-built image and was able to get my devkit with an 8 GB MitySOM-AM62P to boot and have networking support. I did have to edit the /etc/resolv.conf to point to a valid nameserver with the build. Same instructions, just skip the step of coping the Image files and kernel modules.
Here is a link to the image that booted for me:
https://support.criticallink.com/files/mitysom62x/tisdk-debian-trixie-mitysom-am62p-devkit-10.01.10.04.wic.xz
I was able to run an apt update, etc. I have only tested the console and the ethernet ports.
As a side note, our kernel build and associated headers (the git repo) is publicly available. So if our kernel is used we can supply the kernel headers if needed. With this kernel, I don't know if the display will work correctly as we have some patches for the TFP410 I2C control that are needed to enable the output.
With regards,
Mike
Hi Mike,
I did the same setup using the TI Debian SDK v10.00. It booted successfully, and I have the default TI kernel and kernel headers. I also installed the EtherCAT IGH Master.
I want to bring up one point: I entered manual boot mode (by pressing the Escape key during boot) and checked the environment variables. For the device tree, it was using k3-am62px-mitysom-devkit.dtb (provided by Critical Link), whereas TI uses their own device tree — I believe it was something like k3-am62p5-sk.dtb (I don't remember the exact name).
We had previously enabled UART5 in the device tree and made some minor modifications during development with the TI evaluation board. These changes will not work if the Critical Link (CL) version of the device tree does not have UART5 enabled or lacks our customizations.
Therefore, could you please share the kernel device tree source and U-Boot source code provided by Critical Link? That way, we can apply our changes and deploy a working version.
The links to our git repositories and branch names for the kernel and uboot (you'll want the latest / scarthgap release) are at the top of the
Repositories_and_Pre-built_Images page. This includes the dts files you'll need to modify to configure the pinmux and enable the UART5 device. You'll want to update the k3-am62px-mitysom-devkit.dts file.
With regards,
Mike
RE: Debian SDK Not booting in am62p (Am62x dev kit) - Added by Rajkumar Dumala 3 months ago
We’ve now implemented the changes you suggested, and the OS is working fine.
Since we only copied the U-Boot and device tree from the Critical Link (CL) build into the TI file system, we needed to explicitly enable main_uart5 in the device tree. To do this, I performed the following steps:
1.Added the UART5 node in the device tree at the path:linux-ti/arch/arm64/boot/dts/ti/k3-am62px-mitysom-som.dtsi
    aliases {
        serial0 = &wkup_uart0;
        serial2 = &main_uart0;
        serial3 = &main_uart1;
        *serial5 = &main_uart5;*
        mmc0 = &sdhci0;
        mmc1 = &sdhci1;
        mmc2 = &sdhci2;
        spi0 = &ospi0;
        ethernet0 = &cpsw_port1;
        ethernet1 = &cpsw_port2;
        usb0 = &usb0;
        usb1 = &usb1;
&main_uart5 {
    bootph-all;
    status = "okay";
    pinctrl-names = "default";
    pinctrl-0 = <&main_uart5_pins_default>;
    /* Main UART5 is used by USER firmware */
    main_uart5_pins_default: main-uart5-default-pins {
        bootph-all;
        pinctrl-single,pins = <
            AM62PX_IOPAD(0x1d8, PIN_INPUT, 1)    /* (B23) UART0_RXD */
            AM62PX_IOPAD(0x1dc, PIN_OUTPUT, 1)    /* (F20) UART0_TXD */
Device Tree Modifications:
The pin details for UART5 were taken from the AM62P TRM to ensure the correct ball assignments.
Building the Device Tree Using CL Script:
./62xx-build-dts.sh
make[1]: Entering directory '/home/svaya/cl/linux-ti/build-mitysom62x'
  SYNC    include/config/auto.conf.cmd
*** The source tree is not clean, please run 'make mrproper'
*** in /home/svaya/cl/linux-ti
make[3]: *** [../Makefile:651: outputmakefile] Error 1
make[2]: *** [/home/svaya/cl/linux-ti/Makefile:798: include/config/auto.conf.cmd] Error 2
make[1]: *** [/home/svaya/cl/linux-ti/Makefile:234: __sub-make] Error 2
make[1]: Leaving directory '/home/svaya/cl/linux-ti/build-mitysom62x'
make: *** [Makefile:234: __sub-make] Error 2
I ran the 62xx-build-dts.sh script, but it threw an error because it was unable to find the .config file, so I entered the following command fro ti document :
make ARCH=arm64 CROSS_COMPILE="$CROSS_COMPILE_64" dtbs && make ARCH=arm64 CROSS_COMPILE="$CROSS_COMPILE_64" dtbs
whith this it generated k3-am62px-mitysom-devkit.dtb.
After generating the k3-am62px-mitysom-devkit.dtb file, I copied it to /boot/dts/ti/ on the target filesystem.
Then, I rebooted the board.
However, UART5 is still not functioning.
Case 2: I cleaned everything and ran 62xx-build.sh, which successfully generated the .dtb, Image, vmlinux, etc. However, UART5 is still not working.
Could you please guide us on how to properly enable UART5?
Thank you,
Rajkumar
Hi Mike,
Update on the above comment:
It is working now. The issue was that pins B23 and F20 were already being used in the main_gpio_p3_pins_default node for the P3 connector. I commented out those two pins, and now UART5 has started working.
Thank you,
Rajkumar--
RE: Debian SDK Not booting in am62p (Am62x dev kit) - Added by Michael Williamson 3 months ago
Can you check if you disabled the MCAN0 mux options? Usually the first device to claim the resource wins, so if MCAN initializes first it might claim the pins on you.
make sure the lines below are commented out in k3-am62px-mitysom-devkit.dts:
   AM62PX_IOPAD(0x01d8, PIN_INPUT_PULLDOWN, 7) /* (B23) MCAN0_TX.GPIO1_24 */
   AM62PX_IOPAD(0x01dc, PIN_INPUT_PULLDOWN, 7) /* (F20) MCAN0_RX.GPIO1_25 */
Glad you got it fixed! (our comments passed each other!)
RE: Debian SDK Not booting in am62p (Am62x dev kit) - Added by Jonathan Cormier 3 months ago
Thanks for pointing this out. I'd never tried using the dts script without already having run the full build. But this can be resolved by grabbing the make defconfig line from the regular build script and add it.
https://support.criticallink.com/gitweb/?p=linux-ti.git;a=commit;h=7a2fa4c2307057e6c0fba995546f6d006afcd575
This error occurs because the build scripts use an out of tree build using the "O=" argument. If you manually run the commands without that argument, it starts an in-tree build and the kernel will complain if you switch between the two. Running 'make mrproper' should be enough to clean the build and resolve the issue.
Hi Mike,
Hope you're doing well.
We received the AM62A SoM today from Critical Link and inserted it into the AM62x Development Kit.
We flashed the SD card with the reference microSD card image (tisdk-default-image-mitysom-am62ax.rootfs-SDK10.01.00_26-20250220173311.img.zip) provided here:[[https://support.criticallink.com/redmine/projects/mitysom_am62x/wiki/Repositories_and_Pre-built_Images]]
However, when we booted the board, it did not boot. I am sharing the boot log.
U-Boot SPL 2024.04-ti-g96357debfcc1 (Feb 19 2025 - 19:58:02 +0000)
SYSFW ABI: 4.0 (firmware rev 0x000a '10.0.8--v10.00.08 (Fiery Fox)')
Configuring LPDDR4 for 4GB
SPL initial stack usage: 17056 bytes
Trying to boot from MMC2
Authentication passed
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.10.0(release):v2.10.0-367-g00f1ec6b87-dirty
NOTICE:  BL31: Built : 16:09:05, Feb  9 2024
Card did not respond to voltage select! : -110
spl: mmc init failed with error: -95
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
Can you help us bring up the AM62A SoM? Do we need to change the bootloader?
Thankyou,
Rajkumar.
I was just looking into this error case last week. Do you happen to be using a sandisk sdcard?
In the 10.1 SDK u-boot, TI has enabled UHS mode in u-boot to allow booting faster from sdcards. However, in my testing this fails to work properly on specific sandisk sdcards I have in the office. Unfortunately we were using samsung sdcards when we validated the release so it wasn't initially discovered.
I am working on releasing an updated 10.1 sd card image that turns UHS mode back off. In the meantime can you try the 10.0 sdcard image?
https://support.criticallink.com/files/mitysom62Ax/SDK10.00.00_23-20250207115855/tisdk-edgeai-image-mitysom-am62ax.rootfs-SDK10.00.00_23-20250207115855.img.zip
I also just pushed the commit to the mitysom-u-boot-2024.04 u-boot branch. So you could build u-boot and update the 10.1 SDK sdcard image. Similar to how you did the debian image.
https://support.criticallink.com/gitweb/?p=u-boot-ti.git;a=commit;h=990d9851d94bd00cc7a422de7e1b97061a5694d8
cd u-boot-ti
git pull
./62ax-build.sh --install-depends
./62ax-copy.sh #Copy files to sdcard
Hi Mike,
The U-Boot build is working fine. I haven't tried the SD card image you mentioned yet, but I will try it and update you.
Thank you.
Hi Mike,
We have pulled the Ubuntu-based Docker container on top of the MitySOM SDK 10.01.
We built the kernel using the following command:
make O="$BUILDDIR" defconfig ti_arm64_prune.config mitysom-am62xx-devkit.config ti_rt.config
We made some changes there to make Docker work, based on our previous real-time configuration from TI.
@svaya@Pc-17:~/cl/linux-ti$ git diff kernel/configs/ti_rt.config
diff --git a/kernel/configs/ti_rt.config b/kernel/configs/ti_rt.config
index 334c6de72ef3..daf7a5fb9812 100644
--- a/kernel/configs/ti_rt.config
+++ b/kernel/configs/ti_rt.config
@@ -88,8 +88,8 @@ CONFIG_PERF_EVENTS=n
 # profiling. This prevents users from loading eBPF programs
 # but BPF usage within the kernel should still work. Disabling
 # JIT compiler will slow down packet filtering.
-CONFIG_BPF_SYSCALL=n
-CONFIG_BPF_JIT=n
+CONFIG_BPF_SYSCALL=y
+CONFIG_BPF_JIT=y
 # Fine granularity IRQ time accounting is not needed on a
 # production system.
@@ -169,7 +169,7 @@ CONFIG_CGROUP_HUGETLB=n
 CONFIG_CPUSETS=n
 CONFIG_CGROUP_CPUACCT=n
 CONFIG_CGROUP_PERF=n
-CONFIG_CGROUP_BPF=n
+CONFIG_CGROUP_BPF=y
 # HACK: Remove security features with real-time latency effects.
 # Unless you have aggressive latency goals you will most likely
When we run ROS2, we observed that the message publish frequency is around 600 Hz, even though we are configuring it to run at 1000 Hz. This happens while multiple publishers and subscribers are active.
Thankyou,
Rajkumar.
When you run the example on the TI EVM (with SDK 10.1 + RT config), do you see 1000 Hz performance or the same 600 Hz performance?
Rajkumar, Note I added pre tags around your code dumps. You have been using the @ symbols but that only works for single lines. You can easily add the pre tags by highlighting what you want marked as code and then hitting the pre button or using ctrl-p
Note we are not super familiar with ROS but from my quick googling, sending messages around 1kHz does seem like its approaching the limits of ROS2 even on a desktop system. I'm not saying its not possible because I don't know but we should be looking at cpu usage or memory bandwidth usage to see if we are hitting performance limits.
This post seems to indicate there are knobs you can tweak on the message passing system to make it faster but will sacrifice reliability.
https://get-help.theconstruct.ai/t/ros2-hz-topic-increase-publishing-rate/21432
Note that enabling RT in linux, won't make things go faster. RT's job is to make things be more consistent.
I did find this pretty interesting presentation on combining ROS and real-time linux. It may be worth a read if you haven't seen it.
https://ros-realtime.github.io/roscon-2023-realtime-workshop/
(1-25/28) Go to top
