AKError in Cloning the branches of MitySOM
Added by Arun Krishnan over 2 years ago
Following the procedure in the link: https://support.criticallink.com/redmine/projects/mitysom_am57x/wiki/Linux_Kernel_Yocto_for_MitySOM-AM57X, I have used the docker images for cloning the MitySOM branches to the oe-layersetup folder inside the docker. I got the following error messages.
pokyuser@f6d4cbf3d374:/work/oe-layersetup$ ./oe-layertool-setup.sh -f configs/processor-sdk/processor-sdk-06.03.00.106-cl-external-config.txt
/work/oe-layersetup
cloning repo bitbake
Cloning into '/work/oe-layersetup/sources/bitbake'...
warning: redirecting to https://git.openembedded.org/bitbake/
remote: Enumerating objects: 63551, done.
remote: Counting objects: 100% (72/72), done.
remote: Compressing objects: 100% (70/70), done.
remote: Total 63551 (delta 47), reused 2 (delta 2), pack-reused 63479
Receiving objects: 100% (63551/63551), 13.35 MiB | 2.24 MiB/s, done.
Resolving deltas: 100% (47621/47621), done.
Branch '1.40' set up to track remote branch '1.40' from 'origin'.
Switched to a new branch '1.40'
Already up to date.
Note: checking out 'b690030efc87850951e8e3ecf4ae3c1dd1dc9b63'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
HEAD is now at b690030e runqueue: fix multiconfig task dependency filtering
cloning repo meta-processor-sdk
Cloning into '/work/oe-layersetup/sources/meta-processor-sdk'...
fatal: unable to access 'https://git.ti.com/processor-sdk/meta-processor-sdk/': The requested URL returned error: 503
git failed... remaining attempts: 4 sleeping 15 seconds
git failed... remaining attempts: 3 sleeping 30 seconds
git failed... remaining attempts: 2 sleeping 45 seconds
git failed... remaining attempts: 1 sleeping 60 seconds
git failed... giving up...
ERROR: Could not clone repository at https://git.ti.com/processor-sdk/meta-processor-sdk
AK RE: Error in Cloning the branches of MitySOM - Added by Arun Krishnan over 2 years ago
It was an issue with TI's git server which got solved now.. The above discussion can be ignored.. thank you
