Alternative for MM70-314-310B1-1-R300
Added by Eike Feldmeier about 4 years ago
Has anyone an alternative for the MM70-314-310B1-1-R300 since it is no longer availible. I have parts under the SOM i need a higher version like the original one.
RE: Alternative for MM70-314-310B1-1-R300 - Added by Alexander Block about 4 years ago
We actually have a detailed Wiki page (https://support.criticallink.com/redmine/projects/mityarm-5cs/wiki/MXM_Connector_Information) that covers a number of the alternate connectors that are compatible with the MitySOM-5CSx module families.
The new recommended component from JAE is the MM70-314-B1-2-R300.- Same height as the original
- Has 314 contacts loaded instead of the 310 for the original
- The footprint for the 314 pin version would be slightly different as there are the 4 extra pins
- These extra pins are not needed on the SOM and can be left as no connects and/or tied accordingly as shown in the Wiki page
Please let us know if you have any further questions,
Alex
