SWSATA board connector
Added by Scott Whitney over 13 years ago
Hello, We have an application where we are storing data to a SATA drive from our L138. We are in an environment with some vibration and sometimes a bit of a mechanical shock and I am worried about the lack of a latch on the SATA connector. Do you know of a compatible latching board connector that we can swap out for the current one? thanks, Scott
Replies (4)
MW RE: SATA board connector - Added by Michael Williamson over 13 years ago
Hi Scott,
Not offhand? Do you require footprint compatible? A quick search on digikey shows there are latching SATA connectors our there.... Something like:
http://www.digikey.com/product-detail/en/67926-0001/WM19024-ND/711506
SW RE: SATA board connector - Added by Scott Whitney over 13 years ago
I was looking for something with the same footprint. We have your demo board that we are using in our fixture and I was hoping we could swap out the current connector for a latching one. I had seen those molex connectors and it does not look like they are pin compatible.
AB RE: SATA board connector - Added by Alexander Block over 13 years ago
Scott,
Just wondering if you found a drop in replacement. We actually just tried doing this on an in-house test fixture here and I selected a Molex 19103 which is pin-compatible however the footprint isn't quite right and the pins had to be bent a little but the connector ended up flush on fully soldered on the board.
http://www.digikey.com/product-detail/en/0678008005/WM19103-ND/1499151
If you found a replacement can you post what it was exactly?
Alex
Alex,
I haven't had the opportunity to get a SATA connector for our board. That is the one I was looking at. I like to hear you were able to get it flush on the board. I will look into getting some and trying it out. Thanks, Scott
