CMcontinual reboot
Added by Craig Meyers almost 15 years ago
I modified the FPGA code and during the write the board rebooted.
I had bootfpga set to load the fpga automatically on boot so now I'm stuck.
How do I break this infinite reboot loop?
HyperTerminal session looks like this:
Configuring 128MB mDDR
Booting TI User Boot Loader
UBL Flashtype: SPI
Starting SPI Memory Copy...
DONE
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
ARM Clock : 300000000 Hz
DDR Clock : 150000000 Hz
EMIFA CLock : 100000000 Hz
DSP Clock : 300000000 Hz
ASYNC3 Clock : 150000000 Hz
Enet config : 2
MMC 0 Enable : 0
Resetting ethernet phy
Loading FPGA from 0xC0700000 with 0x170000 bytes
UBL Flashtype: SPI
DONE
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
Enet config : 2
MMC 0 Enable : 0
UBL Flashtype: SPI
DONE
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
Enet config : 2
MMC 0 Enable : 0
UBL Flashtype: SPI
DONE
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
Enet config : 2
MMC 0 Enable : 0
UBL Flashtype: SPI
DONE
I2C: ready
DRAM: 128 MB
NAND: 256 MiB
MMC: davinci: 0
In: serial
Out: serial
Err: serial
Enet config : 2
MMC 0 Enable : 0
Replies (6)
MW RE: continual reboot - Added by Michael Williamson almost 15 years ago
Try hitting control-C continuously while booting. If that does not work, you can use the "programming a dead board" technique using the UART loader to reflash the SPI from the ground up. I think that control-C should work for you, though.
CM RE: continual reboot - Added by Craig Meyers almost 15 years ago
Control-C does not work. Tried in both HyperTerminal and Putty.
Also tried dead board instructions with seemingly successful results but still got the autoboot loop:
(AIS Parse): BOOTME received!
(AIS Parse): Performing Start-Word Sync...
(AIS Parse): Performing Ping Opcode Sync...
(AIS Parse): Processing command 0: 0x58535901.
(AIS Parse): Performing Opcode Sync...
(AIS Parse): Loading section...
(AIS Parse): Loaded 9340-Byte section to address 0x80000000.
(AIS Parse): Processing command 1: 0x58535901.
(AIS Parse): Loaded 812-Byte section to address 0x8000247C.
(AIS Parse): Processing command 2: 0x58535906.
(AIS Parse): Performing jump and close...
(AIS Parse): AIS complete. Jump to address 0x80000000.
(AIS Parse): Waiting for DONE...
(AIS Parse): Boot completed successfully.
Waiting for SFT on the OMAP-L138...
Target: BOOTUBL
Target: DONE
Flashing UBL UBL_SPI_MEM.ais (8396 bytes) at 0x00000000
Target: INFO: SPI Memory Initialization passed.
Target: Flashing UBL...
Target: SENDIMG
Target: BEGIN
100% [ ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª ]
Image data transmitted over UART.
Target: DONE
0% [ ------------------------------------------------------------ ]
0% Programming UBL into flash...
50% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
100% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
Verifying...
UBL programming complete
Target: DONE
Flashing application u-boot.bin (260568 bytes) at 0x00010000
Target: SENDIMG
Target: BEGIN
Target: DONE
Programming application into flash...
0%
1% Target: Doing block erase.Doing block erase.Doing block erase.Doing bloc
3% e.ªENDING
4% ªªrget: SENDING
6% ªªªget: SENDING
7% ªªªªet: SENDING
9% ªªªªªt: SENDING
11% ªªªªªª: SENDING
12% ªªªªªªª SENDING
14% ªªªªªªªªSENDING
15% ªªªªªªªªªENDING
17% ªªªªªªªªªªNDING
19% ªªªªªªªªªªªDING
20% ªªªªªªªªªªªªING
22% ªªªªªªªªªªªªªNG
23% ªªªªªªªªªªªªªªG
25% ªªªªªªªªªªªªªªª
26% ªªªªªªªªªªªªªªªª
28% ªªªªªªªªªªªªªªªªª
30% ªªªªªªªªªªªªªªªªªª
31% ªªªªªªªªªªªªªªªªªªª
33% ªªªªªªªªªªªªªªªªªªªª
34% ªªªªªªªªªªªªªªªªªªªª
36% ªªªªªªªªªªªªªªªªªªªªª
38% ªªªªªªªªªªªªªªªªªªªªªª
39% ªªªªªªªªªªªªªªªªªªªªªªª
41% ªªªªªªªªªªªªªªªªªªªªªªªª
42% ªªªªªªªªªªªªªªªªªªªªªªªªª
44% ªªªªªªªªªªªªªªªªªªªªªªªªªª
46% ªªªªªªªªªªªªªªªªªªªªªªªªªªª
47% ªªªªªªªªªªªªªªªªªªªªªªªªªªªª
49% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
52% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
53% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
55% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
57% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
58% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
60% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
61% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
63% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
65% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
66% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
68% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
69% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
71% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
73% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
74% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
76% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
77% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
79% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
80% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
82% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
84% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
85% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
87% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
88% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
90% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
92% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
93% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
95% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
96% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
98% ªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªªª
Verifying...
Application programming complete
Target: DONE
Target: DONE
Operation completed successfully.
Argh. The SPI reprogramming doesn't wipe the u-Boot environment or the FPGA environment, so it just picks back up where it left off. I think we need to update the flashing utility to wipe the u-Boot environment and/or the FLASH environment. Not sure I have a solution for you at the moment, Craig. You've managed to find a path we haven't covered yet!
Let me see what we can come up with, it might take a bit of time, though...
Would this work?
sfh_OMAP-L138 -erase
help sez:
Global erase of the flash memory device (no input files)
Should. You'll need to reflash again the u-Boot and UBL. Give it a try. (good catch, BTW).
sfh_OMAP-L138 -erase -p COM7 worked!!
